94 Ranger Clutch bleeding problem
Old Nov 6, 2004 | 01:22 PM
Waterlog's Avatar
Waterlog
I have a 94 Ranger 2.3 2 wheel drive. I recently put in a new clutch assembly, new slave cylinder, and a new clutch master cylinder. After giving up the fight to bleed the line, I used a vacuum bleeder to make sure all the air was out. I vacuumed from the bottom, and also from the top. I cannot get any pressure built up in the clutch and when the clutch peddle is depressed I can only see the slave move about a quarter of an inch.
All of the parts are installed correctly and all were brand new. Is there some sort of trick to bleeding this system?
Old Nov 6, 2004 | 10:33 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I've seen a lot of posts about this problem, did you bench bleed the master?? Also try a search, there should be a lot of info on this topic.
Old Nov 8, 2004 | 09:28 PM
Waterlog's Avatar
Waterlog
Fixed
We bench bled it by submerging it in a small bucket of break fluid. I finally pulled the master cylinder out and had the auto parts store replace it. I put in the new one and it works like a charm now.
Old Nov 9, 2004 | 08:17 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!
bluemtn95ford
Apr 5, 2015 06:37 PM
264WSM
Jun 29, 2013 07:40 PM
jd88rules
May 28, 2011 12:48 AM
elojsgonz
Nov 18, 2005 12:08 PM
fordranger4x4
Mar 3, 2003 09:33 PM
