General Automotive Discussion
Floor switch highbeam dimmer
Old Nov 6, 2004 | 07:52 PM
gotdiesel's Avatar
gotdiesel
just a thought. if you are down shifting wouldnt your left foot be on the clutch??? that would make it hard to reach the clutch and the dimmer switch at the sametime. just wonderin have fun!!!
Old Nov 6, 2004 | 07:59 PM
94F150-408's Avatar
94F150-408
The problem is being able to reach the mutifunction when your hand(s) are busy going around a mountain turn, they usually arent in the 10 o'clock and 2 o'clock positions, and sometimes you are downshifting. The clutch is a fairly quick manuver that is right next to the floor mount high beam switch, so its much quicker and safer.
Old Nov 6, 2004 | 10:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
I like the multi-function switches, but then my hand is big enuf to stick out a finger and operate the switch with my hands on the wheel. I can usually see that someone is coming around a mountain turn b4 I get into a position where my lights are on them. the M-F switches all operate the same for the lights which makes it easier than "finding" that floor switch with my foot. I wish all the wiper switches operated the same.
Old Nov 7, 2004 | 06:20 PM
nick88f150's Avatar
nick88f150
I agree with the wiper part, I've had trouble figuring a few of those out. As for the floor switch. I like it, but my hand is also big enough to operate the handles on the column while keeping hands on the wheel.
Old Nov 8, 2004 | 06:02 AM
MrOldV8's Avatar
MrOldV8
Ahhh, floor switches...I like em. I miss the high beam switch on the floor.
My '23 Model T has the starter button on the floor. To start the car you have to set the hand brake, turn the ignition switch/key to 'on', pull the choke ****, set the throttle lever (there's no gas pedal), set the spark advance lever, then step on the starter. If the starter doesn't work, you have to get out and crank it.
I'm testing my memory here, but I remember two other floor switches in the late 50's.
1) My dad had a '58 Lincoln, and I remember a button on the floor next to the high beam button that would make the radio seek a higher station.
2) If I remember right some Buicks didn't have a 'start' position on the ignition. You would turn the key to 'on', then press the gas pedal to the floor. There was a starter button under the gas pedal. Once it started, you let off the gas real quick.
Anybody else remember these?
MR
Old Nov 8, 2004 | 07:07 AM
peppy's Avatar
peppy
Yay.........I have the floor switch. MMMMM, older truck, floor switch. Newer truck, column switch.
Old Nov 9, 2004 | 08:30 PM
Caleb1's Avatar
Caleb1
I am 17 and jest bought a nice 84' F-150 and of course it has the floor dimmer, and I love it. I dont even have to think about where it is, jest tap it and go. Lot safer and easier to keep both hands on the wheel.
Old Nov 9, 2004 | 11:58 PM
rebocardo's Avatar
rebocardo
Most likely because of the FMVSS, they do have guidelines for high beam/lamp switches. Plus, the multi-function switch saves a lot of money designing and assembling the car.
Old Nov 10, 2004 | 05:19 AM
theonlybull's Avatar
theonlybull
MrOldV8, i've seen both switches your talking about. our 45 chev 2 ton has a starter on the floor, which makes things interesting in hilly country, and a friends packard(don't know the year) has the starter switch under the gas.
personally, i like the dimmer on the floor, but the one on the colum is not a problem to use either, so i guess i'm split on this one
Old Nov 10, 2004 | 06:00 AM
02FX4Dude's Avatar
02FX4Dude
Originally Posted by Beast12
I think part of the problem is that many of them had to be replaced because they got water, moisture, snow and salt in them. My dad had an 89 F150 and it shorted out and almost caused a fire. Maybe a danger issue? I love it on the floor though!
-Matt
I had that problem in my 87 F150 one night when my boots were covered in slush and salt. I didn't have a fire but the cab filled up with smoke as the switch and wiring fried and the lights flickered. Then I lost the headlight completely for the rest of the way home.
Old Nov 10, 2004 | 06:04 AM
Beast12's Avatar
Beast12
Yeah, basically same scenario here. Was kinda scary! (and smelly!)
-Matt
joannev
1997 - 2003 F150
Nov 22, 2022 07:16 PM
Skorpion007
Jun 15, 2020 10:01 AM
jgilrfr
Aug 27, 2015 11:40 AM
stang_me1990
21
Jun 19, 2012 10:27 PM
Black Ford XLT
Mar 2, 2005 12:34 PM
