E40D slipping ?
Old Nov 4, 2004 | 04:39 PM
Goliath 350's Avatar
Goliath 350
E40D slipping ?
Hello !
I own a 97 F-350 w/ 460 automatic 4x4 with 150k miles on it. The only mods to the truck is a SUPERCHIP and a K&N filter. I do all the regular maintence when recomended. I only use the truck for pleasure and i dont pull anything with it .
I have noticed the tranny not acting right latley, it seems to "fall" into gear at normal driving speed. " it seems like its in a hurry to get to overdrive when i take off "I dont know if its the converter acting up, or its slipping into gear before it should. It wants to go into overdrive at 35mph where it used to go into overdrive at around 45-48.
anyone with knowledge of the E40D tranny ???
thanks for any help !!!
Old Nov 6, 2004 | 05:33 PM
Goliath 350
i just wanted to thank EVERYONE for all there replies, they were very helpful !
Old Nov 6, 2004 | 10:29 PM
Overkill-F1's Avatar
Overkill-F1
Be patient Grasshopper, someone will answer you. ...Terry
Old Nov 8, 2004 | 09:44 AM
gatesj's Avatar
gatesj
Common problems with the E4OD not picking the right gear are problems with the throttle position sensor on the throttle body and problems with the MLPS sensor on the side of the transmission (shaped like a baseball diamond, on the driver's side). Also the vehicle speed sensor can mess things up, does the speedometer work right?
Old Nov 9, 2004 | 05:09 PM
Goliath 350
Talking
thanks for the reply...
the TPS has 3 wires comming out of it...how do i check to see if its working properly? and if it's not.. then how can i adjust it ?
the speedo is working fine.
what is the process to check the MLPS ?
Old Nov 9, 2004 | 07:11 PM
351coupe's Avatar
351coupe
Heres a free bump to the top.I want to keep this thread alive for you,and myself since I'd like to know the procedure for testing the tps and mlps too.I have the same truck with 100k fewer miles and my E4od is acting up too.By the way what differences did you notice when you installed the Superchip.A chip is my next buy.They claim noticeably firmer shifting from stock when you put it in???
Sorry I cant be a help to you,but somebody will jump in with the info!
Old Nov 10, 2004 | 03:32 PM
gatesj's Avatar
gatesj
I don't know the procedures, but both are in the Haynes repair manual for about $15.
Old Nov 10, 2004 | 06:11 PM
Goliath 350
Hey 351
i bought a "SUPERCHIPS" chip from motorhaven about 8 months ago. After i installed it i took the truck out for a test drive and noticed a diffrence right away in the power and the shifts. It wasn't a BIG diffrence but it did improve the firmness in the shifts. Only noticed a lil diffrence in the HP about 5-10 gain i think. The milage was improved but not enough to get excited about.
Old Nov 22, 2004 | 10:52 PM
Commo's Avatar
Commo
Mine is a 96 F150 4X4 Super cab.
It seems that 2nd is slipping and reverse may be starting to slip.
When I am on a hill if I put in 2nd it just sits there awaiting further instructions.
If I put it in 1st or D it starts to move.
When in reverse it just sits there until I give it more pedal.
Any thoughts on this?
Thanks
Old Nov 23, 2004 | 11:00 AM
gatesj's Avatar
gatesj
It won't move in 2nd without a fair amount of throttle. Think about it, it's a higher gear ratio.
Is this a change in behavior?
Old Nov 23, 2004 | 09:20 PM
Commo's Avatar
Commo
I bought it used and didn't notice it being slow to move in 2nd and reverse when I took it for a test drive.
Old Nov 24, 2004 | 09:39 AM
gatesj's Avatar
gatesj
My 351 4x4 truck is like that. My 300 4x2 truck is a little more quick to take off if you just take your foot off the brake but it's lighter too. Both have transmissions that are just fine. I understand that if it's slipping badly you get jerking or it feels like it's in neutral or both. It won't move easy in 2nd. "2" picks second, not 1st and 2nd. You start out in 2nd gear if you pick 2. I wouldn't worry about it unless it shudders or won't move when you step on it. You'll also get a blinking OD light if there is slippage.
lincolnboy73
13
Aug 17, 2012 04:41 PM
hatchet
Jun 13, 2010 03:57 AM
a_o_dell
1983 - 2012 Ranger & B-Series
Mar 10, 2010 09:44 PM
wclassiter
May 8, 2009 12:59 PM
F250_96_460_E4OD
May 30, 2002 04:46 PM
