I know this probably dosen't fit in this forum, but wasn't sure where to put it, and you guys have helped out awesome on other things already. I have an aluminum toolbox for my ranger, and I broke the key off inside the lock. Was just wondering if anyone knew of a way to remove it, short of going to a locksmith. Thanks in advance for any help....
I realize the answer is likely "no", but is the box open? If it is can you take the lock apart from the back. I work in server rooms and lots of morons brake the keys off in the locks on server racks.
The other ways I have removed key parts is to JB Weld something to the end and pull it out. Sometimes superglue or solider works too.
Yes, the box is open, and that was exactly what I was thinking about doing G2IC_WRAITH, taking the lock out, and then just gluing something to the end of the broke key and trying to pull it out. Yes, I can see the broken off portion of it.
If you can see the broken off portion, then I'd use a straight pin or needle to apply a very small coating, just enough to dampen the broken edge of the end of the key you have.
DON'T apply too much, as it will squeeze out & bond the tumblers. All you need is enough to just dampen the broken edge.
Then slowly blow your breath into the lock cylinder, to add plenty of surface moisture to the broken edge. This will help the adhesive react instantly to bond the two ends together when they touch.
Then insert the broken part into the lock such that the broken edges match.
You could hold it in place with something like "Duct Seal", modeling clay, or maybe tape & give it plenty of time to dry.
I was and to remove a broken key in a mini van door lock, used 2 X-acto knife blades, careful not to cut myself, one down each side of the key then pressed the blades together and pulled it out.
Now the real magician was the lock smith who took the partical key and made a brand new one that works, whiah was graet as the other keys were stolen.
I broke a key off one time - went to the local hardware store, bought one of those 'cheap' dental picks (looks kinda like a question mark), slipped it above the key, pressed down with moderate pressure, pulled back, the broken key popped out - quickly!!!!
Went back to the hardware store, bought more of the 'cheap' dental tools.
I have at least one of each, including the 'dental mirror'.
