steering wheel lights
Old Nov 4, 2004 | 01:09 PM
4Cammer72's Avatar
4Cammer72
the lights on my steering wheel flicker . no pattern , i think just worn contacts. any info on correcting this problem.
Old Nov 4, 2004 | 11:02 PM
broken wire's Avatar
broken wire
The wiring to the steering wheel has no contacts, it is done by a roll of flat wiring called the clockspring, wraps up in one direction under the steering wheel as the wheel is rotated in the one direction and unwraps in the other direction, the clockspring wiring breaks from the lubricant that is used at the factory gets to thick and causes the wiring to not separate when the wheel is turned, causing the roll of wiring to snap. The clockspring operates everything on the steering wheel including the air bag. Clockspring is serviced as a complete unit. Takes no longer than an hour to install.
This is the most logical part of the flickering lights. Broken Wire
Old Nov 5, 2004 | 10:33 AM
4Cammer72's Avatar
4Cammer72
Thanks , Got Any Idea How Much It Costs
Old Nov 5, 2004 | 10:48 AM
ExpyBob's Avatar
ExpyBob
Ford Parts Online says
CLOCKSPRING, Expedition, w/o Cruise Control, To 8/13/01 99-02 $46.23 your cost $35.13
CLOCKSPRING, Navigator 99-02 $38.84 your cost $29.52
Bob
deljac
Feb 2, 2017 07:49 PM
MDSLIGHT
Jan 20, 2017 10:50 AM
Bird-Dog 250
Feb 15, 2016 09:07 AM
jhcorley
Mar 25, 2015 06:29 PM
Battlemark
Large Truck
Feb 17, 2015 09:37 AM
