Ranger Year Ranges
Old Feb 4, 2000 | 11:58 AM
jnland's Avatar
jnland
Ranger Year Ranges
Hi,
I have a 94 Ranger XLT 2.3L with the Mazda 5 speed transmission. My son just wrecked it and destroyed the body but the engine and transmission are still ok. Incidentally, it's a short wheel base truck. What I need to know is the possible year range and Models of small Ford trucks and/or sedans that this engine and transmission will fit in? Any help would be greatly appreciated.
Thanks,
Jim
Old Apr 17, 2002 | 11:36 AM
pimpdaddy's Avatar
pimpdaddy
Ranger Year Ranges
the 2.3 motor and trans will fit in a 93-97 ranger for sure. it may go as far back as 88 and up to the 99 models. i think 2000 was the year that they changed from the 2.3 to 2.5.:-X11
Old Apr 17, 2002 | 06:15 PM
aksniper's Avatar
aksniper
Ranger Year Ranges
The 2.3L and transmission will fit all the Rangers '93-'97. As far as anything newer than that...you'll have to ask around. I believe in '98 or '99 Ford switched to the 2.5L for the year. But they are back to the 2.3L for whatever reason. I believe half way through '01 to present, they are using a new 2.3L twin cam. So really...If I were you I would look for a '93-'97 Ranger to build up. If you wanted to build a 4x4 out of it, I'd say go buy a junk '93-'97 Ranger and stroke the 2.3L up to 2.85L, bore out the cylinders, new roller cam, new head (ported of course), increase the compression ratio, and by the time you're done, be almost like throwing a 3.0L in a 4x4 but yet you've done it with an I4. Just a thought if you and/or your son wanted a project and a 4x4. Hope we answered your question for you and then some possibly. Best of luck to you.
James
Old Apr 17, 2002 | 07:42 PM
bubbernator's Avatar
bubbernator
Ranger Year Ranges
My '98 is a 2.5 standard trans. The Haynes people publish the same repair book for the Ranger and Mazda B series. Probably not a whole lot of difference between engines and transmissions.
Good Luck.
CB
Old Aug 4, 2002 | 03:41 PM
cubster's Avatar
cubster
Ranger Year Ranges
The engine and tranny will fit any Ranger from '82-'98, Mazda's from '93-'98. Transmision may even fit newer models. Engine wiil fit others also, even the Mustang and T-bird.
Old Aug 4, 2002 | 05:41 PM
johnchik's Avatar
johnchik
Ranger Year Ranges
The 2000s still had the 2.5 l engines
Old Aug 6, 2002 | 04:12 AM
Magic684's Avatar
Magic684
Ranger Year Ranges
Your right, the cast is the same from 82-2000, the 2.5 is just stroked. But in 2001 they completley changed the engine, making it non innerchangeable.
Old Aug 6, 2002 | 04:23 AM
Magic684's Avatar
Magic684
Ranger Year Ranges
Nighteyez
Oct 18, 2014 12:41 PM
duckwing
Sep 22, 2014 06:03 PM
tjcanno
Aug 2, 2009 11:28 AM
Jim in S. Tx
May 31, 2003 02:31 PM
