Sponsored by: Real Truck
F450 Engine(?) Screech
Old Sep 21, 2014 | 09:56 PM
duckwing's Avatar
duckwing
My F450 2010 class C motor home has the V10 engine. In the RPM range of about 2200 - 2300, there is a screeching sound I believe is from the engine area. It does not matter what transmission gear I'm in thus the vehicle speed is not a factor - only happens in that engine RPM range. Seems to happen when slowly accelerating/decelerating through the 2200 - 2300 RPM range or continues to screech if I maintain that RPM. If I drop back or increase RPM out of the range it quits. If I accelerate thru the range a little quicker it doesn't happen. Also does not happen when parked and the engine is sped up. Any thoughts?
Jim
Old Sep 22, 2014 | 06:15 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE duckwing.
My guess would be the idler or the tension pulley on the serpentine belt is worn. I replaced mine at 85,000 miles.
Old Sep 22, 2014 | 06:35 AM
Tom's Avatar
Tom
Does it change when you turn the air conditioner on or off?
My first thought was in the serpentine belt system, but that doesn't care if the truck is in gear or not.
Old Sep 22, 2014 | 08:16 AM
duckwing's Avatar
duckwing
I did not try AC ON/OFF but will.
Vehicle has less than 30,000 miles on it.
Thanks - Jim
Old Sep 22, 2014 | 01:29 PM
phillips91's Avatar
phillips91
My bronco blew the ac clutch out a while back and it would make a screeching sound when engaged, but it did it at all rpms.
Old Sep 22, 2014 | 04:44 PM
duckwing's Avatar
duckwing
My screech occurs only in the 2200 - 2300 RPM range. On the highway that is the RPM for 60 MPH. Right where my wife likes to drive.
Old Sep 22, 2014 | 05:35 PM
Tom's Avatar
Tom
Tell her to drive faster!
Old Sep 22, 2014 | 06:03 PM
duckwing's Avatar
duckwing
Usually that's not an issue but she has decided that's how fast the RV/tow vehicle should go.
Is that a HookEm smiley face.
Vette1003
1997 - 2003 F150
Apr 10, 2016 07:43 AM
2002f25028904
Modular V10 (6.8l)
Jan 2, 2014 07:58 AM
tommyleea
Aug 9, 2009 07:54 AM
gino93
Nov 14, 2001 10:00 PM
