Clutch Problems
Old Aug 3, 1999 | 01:17 PM
Jim in S. Tx
Guest
Posts: n/a
Clutch Problems
I have a 1994 Ranger 3.0. I have worked on different rangers for years and never seen this. I had to replace a worn out pilot bushing and resurfaced the flywheel, replaced the clutch, Pressure plate, throw out bearing, reassembled , bled the system and No Clutch pedal!. I have now replaced the slave cylinder and clutch master cylinder and re-bled...nothing! I pulled it all back down and compaired all tolerences with old part, no problem. Any suggestions or ideas anyone? I'm stumped, and sick of pulling that transmission! Jim
Old Aug 4, 1999 | 12:01 AM
tyson's Avatar
tyson
Clutch Problems
Old May 29, 2003 | 02:24 PM
zitro101's Avatar
zitro101
Clutch Problems
Jim,
sorry I can't help you with your problem, but I have to
replace my clutch . Can you give me an idea of the difficulty in doing so? What is the process to drop the
transmission? Do I need an alignment tool for the clutch plates? Do you have a good source for instructions?
Thanks,
timo
Old May 30, 2003 | 11:04 AM
jhdaniels's Avatar
jhdaniels
Clutch Problems
Go to Autozone or Advance and get a Haynes Manual.....it will help alot
jhdaniels
Old May 31, 2003 | 02:31 PM
rickh6155's Avatar
rickh6155
Clutch Problems
Jim:
Had this problem with my 96 Ranger. Only thing that remedied it was to bleed the clutch master cylinder on the bench, with the cylinder itself facing up, plunger down. This is kinda tricky, because you have to press on the ball at the end of the tube while pressing down on the cylinder, allowing the shaft to go up into the cylinder, and hold the reservior up at the same time. You could probably build a jig to hold all of the stationary stuff and free up some hands or get someone to help you out. What this apparently does, is to bleed out the air that is trapped when the master cylinder is in its normall mounted position that I tried every imaginable way, even those methods outlined in Haynes/Chilton, to bleed out. My original mistake was to allow the reservior to go dry while bleeding the slave cylinder using the usual methods, thus allowing air to enter the system.
Good luck and give it a try!!!
Rick
Zack09
Oct 5, 2016 09:05 PM
Diesel wyatt
May 11, 2015 09:51 PM
bluemtn95ford
Apr 5, 2015 06:37 PM
Frozen_Joker
17
Apr 10, 2014 08:06 AM
JeremyJudd
24
Jul 9, 2010 10:03 AM
