how do i remove/clean rust from an intake
Old Nov 1, 2004 | 09:47 AM
c-m-d's Avatar
c-m-d
Exclamation how do i remove/clean rust from an intake
i have a 390 4bbl intake that i got from my uncle......but it sat in his garage for ever and its all rusty inside......what should i do to clean it?
and i have a holley 600cfm 4bbl carb but the secondary jets are way too big for the secondary holes on the intake who makes a good, cheap adapter plate?
thanks
CMD
Old Nov 1, 2004 | 10:20 AM
Mike G's Avatar
Mike G
Take it to your local machine shop and spend a couple of $$ to have it hot tanked and cleaned...
thanks
CMD
I think what you are saying is that the bores for the secondaries are larger than the bore holes in your manifold. You have the wrong type of carburetor, like a spread bore C$&vy. There are open adapter/spacer plates you can buy from Ebay or your local parts store if you decide to keep the carb for your motor.
--Mike
Old Nov 1, 2004 | 10:40 AM
c-m-d's Avatar
c-m-d
is there anything I could do to get it clean other than having it tanked...(i dont like to spend money when i dont have to)
thanks
CMD
Old Nov 1, 2004 | 10:42 AM
Mike G's Avatar
Mike G
A baby bottle washer and some sort of acid based chemical that eats rust would probably to the trick.
--Mike
Old Nov 1, 2004 | 10:46 AM
c-m-d's Avatar
c-m-d
is there any way i can take apart the manifold to clean it?
Old Nov 1, 2004 | 11:01 AM
Mike G's Avatar
Mike G
You are referring to the 70 pound hunk of cast iron, correct? There is no taking tham apart, unless you are refering to the plate on the underside. This can be removed as it has threaded rivits, but that just blocks the underside of the manifold, it does not gain you access to the inside....
--Mike
Old Nov 1, 2004 | 05:44 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
You can use some thinner and a brush to get some of the rust and crap out of it. An air compressor will help blow some junk out too. You can wet sand it with some emery but may have a problem getting way inside of it. Just blow or flush it very well before using it. Having it tanked or soda blasted will achieve the best results as recommended. G.
Old Nov 1, 2004 | 09:07 PM
baddad457's Avatar
baddad457
Easy-Off Oven cleaner------------------- HOT TANK IN A CAN Just don't spray yourself with it.
Old Nov 2, 2004 | 05:07 PM
c-m-d's Avatar
c-m-d
hay i have a holley 4bbl 600cfm carb....i was wondering if anyone would would like to trade...........i am interested in a 4bbl holley standard flange vaccume secondary
cowboyty
Apr 11, 2007 05:42 PM
c-m-d
17
Jan 21, 2005 10:50 AM
c-m-d
Dec 10, 2004 10:42 PM
c-m-d
Nov 21, 2004 07:03 AM
94blueford
13
Oct 19, 2003 08:00 PM
