400 adding a 4bbl question
Old Apr 6, 2007 | 12:15 PM
cowboyty's Avatar
cowboyty
I have a stock 400 with stock exhaust manifolds running a 2bbl carb. I am replacing the carb with a Holley 650 I think model 6210 manual choke and manual secondaries. The intake manifold I bought from a salvage yard and its an Offenhouser intake. It has been modified by welding plates onto it to eliminate the valley pan, and was told it probably came off a pulling truck or something. I didn't know if anyone has heard of these intakes or any idea of what it might gain me in horsepower?
Thanks
Old Apr 6, 2007 | 01:16 PM
packlet's Avatar
packlet
according to http://www.mustangsandmore.com/ubb/D...1CIntakes.html
there were several Offy dual ports avaialble for 351m/400's.
dunno what the differences between the models might be, but i've heard good things about 'em, although they seem to be pretty hard to find these days.
Offenhauser Dual Port 400 (P/N 6033-DP)
- low rise dual port with Holley carb bolt pattern
- not CARB emissions approved
- advertised RPM range: idle-???
- '71 later 400
Offenhauser Dual Port 400 (6034-DP)
- low rise dual port with spread bore carb bolt pattern
Offenhauser Dual Port 351M (P/N 6141-DP)
- '75 and later 351M
Old Apr 6, 2007 | 01:23 PM
beartracks's Avatar
beartracks
Valley pans on a 400 are recommended but not required. If you have plates welded on the sides of the manifold it's probably originally for a 351C
Old Apr 6, 2007 | 02:34 PM
cowboyty's Avatar
cowboyty
its a dual plain intake with the oval holes and there is about a inch and half gap between the plate for the valley pan and the bottom of the intake. I had to put a spacer on it to get the carb to fit. I will try to get some photos this weekend.
Old Apr 6, 2007 | 02:39 PM
53fatfndr's Avatar
53fatfndr
Can you pull any numbers off of the intake?
Old Apr 6, 2007 | 02:41 PM
cowboyty's Avatar
cowboyty
I will get them this weekend.
Old Apr 9, 2007 | 11:18 AM
cowboyty's Avatar
cowboyty
The only number I can find on it is 360. It has 360 on the top side on the front and rear of the intake. I haven't gotten photos yet, but hopefully in next day or so.
Old Apr 11, 2007 | 08:15 AM
cowboyty's Avatar
cowboyty
I know have a photo of it in my gallery under project and new intake and carb.
Old Apr 11, 2007 | 09:42 AM
packlet's Avatar
packlet
that's a low-rise, single plane design, which typically trades off reduced low-speed torque for improved high-rpm horsepower.
Old Apr 11, 2007 | 09:49 AM
cowboyty's Avatar
cowboyty
Thanks For The Help.
Old Apr 11, 2007 | 05:42 PM
grego's Avatar
grego
It would be a good candidate for machining for a multi-port EFI conversion
Thundare
Jul 6, 2012 08:02 PM
HoustonGuy
Jan 10, 2012 06:54 PM
mdr617
Mar 13, 2011 03:48 PM
icuhatn99
Feb 5, 2006 10:35 PM
serving_time
89
May 25, 2004 07:25 PM
