Waste Gate VS Boost
Old Dec 1, 2004 | 12:45 AM
  #46
rjwood5's Avatar
rjwood5
I disconnected the wastegate and capped off both the red line and the inlet. MPG jumped up by about 4 mpg. Is this for real or am I not seeing something? I don't have a boost guage so just keep the RPM under 2500. Everything is stock on this '99 PSD F250 Crewcab with the 6 speed manual tranny. Am I safe by keeping RPM under 2500 or do I need a guage?
Thanks,
Randy
Old Dec 1, 2004 | 12:52 AM
  #47
farmb0y's Avatar
farmb0y
I would think 4 mph is pretty high just from pulling your red line. You shouldn't have to worry about overboosting, the wastegate will still open, just not as soon as it would with the red line connected.
Old Dec 1, 2004 | 01:02 AM
  #48
BigRed350's Avatar
BigRed350
A dumn question maybe, but does a '97 even have a wastegate? If so, I can't seem to find it!
Old Dec 1, 2004 | 02:17 AM
  #49
18vtx00's Avatar
18vtx00
i tried it on mine a few months ago, no gauges though.
i actually thought the power was the same if not maybe a little less and the mileage stayed the same so i put it back on for now.
bone stock 96psd.
maybe more power if i added a chip but not stock on mine.
Old Dec 1, 2004 | 07:21 AM
  #50
psdpower's Avatar
psdpower
Big Red, no 97 and older PSDs don't have a wastegate.
Old Dec 1, 2004 | 07:27 AM
  #51
BigRed350's Avatar
BigRed350
Thank you! I can now stop looking for one! Do you know how they regulate the boost.....or do they??? Is it just full boost all the time???
Old Dec 1, 2004 | 09:56 AM
  #52
smeezy's Avatar
smeezy
if this is true, how did the guy above you disconnect it?
Old Dec 1, 2004 | 10:00 AM
  #53
mech2161's Avatar
mech2161
Kinda wondered same thing. On 140 setting I get 30 psi. with the hose on the clamp.
Old Dec 1, 2004 | 11:06 AM
  #54
y2kexc's Avatar
y2kexc
flip chip...
Originally Posted by mech2161
I just ordered a 6 way flip chip, stock, fast idle, 50, 75, 100, 145 (bug spray). I'll start a new thread when I get it and we'll see how it does.
Hey mech......where did you get the flip chip ? And what make ?
Sounds a little better than the one I just installed Bullydog =stock, 50, 75, 100
I hope you have better luck than I'm having. I keep getting a service engine soon light on after about 30mi of driving.......
Old Dec 1, 2004 | 11:09 AM
  #55
psdpower's Avatar
psdpower
I don't know what he disconnected, but it wasn't a wastegate. The original PSD , 94.5-97, did not have a wastegate from the factory. This thread has info on how the 94.5-97 trucks work: https://www.ford-trucks.com/forums/s...ight=wastegate+
Old Dec 1, 2004 | 02:54 PM
  #56
mech2161's Avatar
mech2161
Check my signature for the brand. Can't say were from (rules). No problems at all. I ordered stock, 50, 75, 100, 140, fast idle.
Old Dec 1, 2004 | 04:49 PM
  #57
18vtx00's Avatar
18vtx00
so i guess the thing i thought was a waste gate is actually the ebpv that i could not find?
because it seems to be sticking in the am as i have read on some threads here.
thanks
Old Dec 1, 2004 | 06:42 PM
  #58
wingit1x's Avatar
wingit1x
Ok, so I've read this thread and the above referenced thread mentioned by PSDPOWER. I'd like to ask this qestion, though slightly off topic. I have a '97 which does not have a wastegate, we've determined. Its an automatic. If I take off from a light rather hard, but not floored, when it shifts to third (overdrive off), it feels like I loose my boost and sounds like it too. I don't have gauges yet, but the truck lags suddenly, loses momentum, and I hear a psssshhhhhhhttt sound (like that technical term?) that sounds like all the air has been released from a tire or something. I always assumed it was the wastegate. If I don't have one, is there something else that could possibly be going on?
Old Dec 1, 2004 | 06:50 PM
  #59
psdpower's Avatar
psdpower
Kinda hard to diagnose sounds over the internet. If you can get a boost gauge just to hook up temporarily it would be obvious if it were a boost issue or something else.
Old Dec 1, 2004 | 07:20 PM
  #60
Turbo_Whistler's Avatar
Turbo_Whistler
y2kexc,
are you still havin problems with your bullydog? hows the power increase? i have been considering getting that same chip here around the holiday sometime, any input? thanks
