Sponsored by: Innova
amp shuts off :(
Old Nov 16, 2004 | 01:04 AM
RomerB2's Avatar
RomerB2
A capacitor won't help this situation, this is a problem with his amp shutting off, a capacitor only helps your system sound better with better peaks, it adds an extra source of battery that is closer, so the energy dosn't have to travel so far from battery to amp, it only intesifies notes.
Old Nov 16, 2004 | 01:03 PM
t_dickie's Avatar
t_dickie
That's not what I understand a capacitator to do. A capacitator will hold power until it is needed, i.e. when the amp has to put out peak power. His problem is that the alternator cannot produce the necessary power to run everything when the amp is working its hardest. A similar thing will happen if you have your stereo on when the car isn't running, like at a bush party or somethin. Once the stereo has drained the battery down to around 8 volts, the amp will protect itself. There designed to work somewhere between 8 and 14 volts, give or take a bit. Anyway, when the amp is drawing max power, the cap will supply what the alternator cannot produce. Then after, the alternator will charge the capacitator back up.
Trevor
Old Nov 16, 2004 | 03:03 PM
RomerB2's Avatar
RomerB2
You're right, the alternator will not produce enough power to power the amp, so it transfers over to the battery, from there it's distributed through your fuses, and goes through wiring to your amp, where then it is used. The capacitator is also known as a stiffening cap, because on hard hit notes, where your peak power is used, the cap acts as a closer battery source. I don't personally think that you're running enough wattage to make the amp go into protection mode, I think there is something wrong with the wiring. If not, I wouldn't recommend a cap, I would recommend you putting in an additional battery, and run a lead from alternator to it, but have it where it's solely used for your amp, that can be both cheaper than a cap, and work better.
Old Nov 22, 2004 | 12:26 AM
Twisted Ranger's Avatar
Twisted Ranger
The cap was suggested to help -w- the dimming light problem, not the amp shutting off. That's why I asked about the subs. DVC or SVC and how are they wired. I think the amp's seeing too low of an impedance, but can't say for sure untill I know more about the wiring. That's what it sounds like just from what's been written here.
Old Nov 22, 2004 | 10:08 AM
cgl's Avatar
cgl
Originally Posted by RomerB2
... I wouldn't recommend a cap, I would recommend you putting in an additional battery, and run a lead from alternator to it, but have it where it's solely used for your amp, that can be both cheaper than a cap, and work better...
Agreed. Cap's only have a limited amount of discharge available. Which is only really useful for peak and hard hits, releaving your charging system for that second (helping to eliminate the dimming light syndrome). A secondary battery (try a orbit spiral) is a better option as long you use an isolator.
Old Nov 23, 2004 | 12:01 AM
RomerB2's Avatar
RomerB2
But the dimming lights still dim even with a cap.. depends on how much money you spend tho
hreyesg
Jul 17, 2013 07:47 PM
Bob Gervais
Mar 8, 2010 05:40 AM
ford12508
Sep 22, 2009 11:54 PM
Fordzilla1993
Oct 15, 2005 02:43 PM
JoeBob1901
Feb 9, 2004 09:09 AM
