Ring and Pinon?
Old Oct 31, 2004 | 12:22 AM
velella's Avatar
velella
Question Ring and Pinon?
My 75 F-350 developed a rear end noise in Baja that was speed related (50 plus only... and disappears on coasting) - a rhythymic thumping with a slight metallic component. I intially thought u-joints... so I replaced all and the middle shaft bearing - still have noise. Checked right rear bearings today and while outside was loose noise is still there.
Think bad gears or something in the rear end. Any ideas? I am going to pop the rear end cover and change differential juice tomorrow.
Anyone know a good (cheap) source of new gears?? Thanks
Old Oct 31, 2004 | 12:25 AM
Mil1ion's Avatar
Mil1ion
Rear gear question.
Not 73-79 Truck specific.
Thread will be moved to the drivetrain forum.
https://www.ford-trucks.com/forums/s...d.php?t=248773
Old Oct 31, 2004 | 01:00 AM
85e150's Avatar
85e150
Google will give you lots, but gear sets are hard to find this evening.
Try for starters these lads. $275 or so if I read it right.
http://www.gearsareus.com/GearsAreUs...kpartsford.htm
Old Oct 31, 2004 | 10:07 PM
velella's Avatar
velella
Thanks... My next step is opening the rear end and see the damage... then spending the $$$. I have never done one so will probably take it somewhere and have it done. probably about a grand total I am guessing.
Condor555
Mar 18, 2020 06:22 PM
Reave1
Sep 16, 2007 10:05 PM
Baja Camper
Jun 24, 2005 06:45 AM
Randyb12
Offroad & 4x4
Mar 14, 2005 12:05 AM
BigRebel
Jan 9, 2000 04:49 PM
