Engine Idle Control
Old Nov 10, 2004 | 02:55 PM
  #46
mejer1's Avatar
mejer1
Hey me1mckee,
I have a 04 and was looking at hooking up your idle control. I looked above the throttle pedal but could not find a wire bundle marked customer access. I did find the wires above the parking brake. hoping you could help me out a little more, I don't just want to go hooking anything up wrong and make my baby go boome.
Thanks
John
Old Nov 10, 2004 | 08:24 PM
  #47
RealMenPowerstroke!'s Avatar
RealMenPowerstroke!
Originally Posted by Lazy Cat
Thanks for the info Jim. I ordered my truck last week and expect it around Christmas. We'll give it a try then.
Gary
So what's the wife getting you for Christmas???
Best of Luck,
Corey
Pictures, pictures, pictures... We need pictures...
Old Nov 10, 2004 | 08:37 PM
  #48
me1mckee's Avatar
me1mckee
mejer1,
With the dash access panel removed, look from below the steering wheel through the metal framework of the dash to the area above the throttle pedal. OR, locate the OBD connection (blue and black plug at bottom of dash near your right leg) and follow the wires up. There will be one single wire sticking out of that bundle about a foot or so up the bundle (yes its pretty far into the dash, difficult to strip the wire). This bundle will be wrapped with a tag that reads "customer access wires, ....refer to Body Builder manual for instructions.....". The wire that you are looking for is WHITE with a LIGHT BLUE stripe, again, it is the ONLY wire sticking out of the bundle and should have a black rubber tip on it- this wire is 12 volts power and should not be touched to anything with the ignition on. I used a normal glow toggle switch and mounted it beside of the little vent just above the access cover basically in front of the ignition switch. This spot is easy to run the wires to from both connections, also there are two large ground posts directly behind it and one has a tab that can be pulled up and connect a spade plug right onto it for your switch ground without extra screws or holes. OK, sorry this was so long but I hope it clears up any questions anyone might have. Happy to help any time, Mat
Old Nov 10, 2004 | 08:47 PM
  #49
me1mckee's Avatar
me1mckee
Question Can't add pics.
How do I add pictures? I can't attach them I know cuz it says that in my rules box at the bottom, but can I insert them here from my computer? I would like to add some pics of the wiring and also those pesky unidentified plugs I found. Thanks for any help, Mat
Old Nov 10, 2004 | 08:49 PM
  #50
SBV45's Avatar
SBV45
Try putting them in your gallery. Then refer from there. Or put them in some other web site and refer to them from that url.
Old Nov 10, 2004 | 08:59 PM
  #51
me1mckee's Avatar
me1mckee
AH, I did not know that I could transfer within the same site... excellent. Thanks SBV45.
Old Nov 11, 2004 | 07:44 PM
  #52
me1mckee's Avatar
me1mckee
Trying pics.
[img][/img]Ok, I'm trying to insert a picture here from my gallery, hope it works.
Old Nov 11, 2004 | 07:47 PM
  #53
me1mckee's Avatar
me1mckee
Question Great
Ok, the picture worked, so here is another better one of those weird plugs under the dash. Does anyone know what the heck these go to? They are above the parking brake and were pushed way up in the dash and fell out when I was fishing for the throttle/ PTO connections. Any help is always appreciated.
https://www.ford-trucks.com/user_gal...oid=59879&.jpg
Old Nov 11, 2004 | 07:48 PM
  #54
me1mckee's Avatar
me1mckee
For other pics try going to my gallery and looking if you have any ideas what they are for. Thanks, Mat
Old Nov 11, 2004 | 07:52 PM
  #55
me1mckee's Avatar
me1mckee
Just one more..
I promise this is the last picture, it is for mejer1. This is the best shot I could get of the wires above the throttle before I connected to them. Hope it helps.
https://www.ford-trucks.com/user_gal...oid=59877&.jpg
Old Nov 11, 2004 | 08:33 PM
  #56
mejer1's Avatar
mejer1
Hey me1mckee,
Thanks for the picture. And nice description of what I needed to find. I found exactly what I needed, exactly where you said it would be. I will hook it up this weekend.
Thanks
John
Old Nov 12, 2004 | 08:42 AM
  #57
Lazy Cat's Avatar
Lazy Cat
Best of Luck,
Corey
Well, since the business is buying the truck, I'm hoping.....LOTS!
Gary
Old Nov 13, 2004 | 02:16 PM
  #58
me1mckee's Avatar
me1mckee
Mejer 1,
This is a little off the subject of this thread, but does your remote start with turbo cool feature have a temp sensor or a timer? I would like to have something that can run until the turbo is 300 deg, not for 10- 15 minutes. That way if it only needs to run for 3 minutes b/c I wasn't hammering wide open before stopping, I don't waste all that fuel (idling one hour is equivalent to driving 33 miles approx.). Glad you found the wires, it has made a big difference with warm up time in the AM for me and runs smoother, so it was a great little add- on for 4 bucks.
Old Nov 13, 2004 | 04:22 PM
  #59
535moe's Avatar
535moe
Does the 04 manual trans need to have the resistor like the 05, and if so does anyone know which wires would be needed.
Old Nov 13, 2004 | 04:44 PM
  #60
mejer1's Avatar
mejer1
Me1mckee,
My remote starter has a timer on the turbo cool down. It can be set for 1 min., 3 min., 5 min., or 10 min.
Also hooked up the switch for the high idle today, it works great. thanks
Also it might be a good thing for you to add the instructions for this to the new Tech folder.
John
