Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Air chisel
Old Oct 29, 2004 | 02:32 AM
Oval_obsessed's Avatar
Oval_obsessed
Air chisel
How good do they work? I am kind of tired of grinding the rivets off and was wondering if an air chisel would work better. What are your guys experiences with them? Are they worth buying? What brand and any certain attachments?
Old Oct 29, 2004 | 02:59 AM
Torque1st's Avatar
Torque1st
Posting Legend
I have a "Mechanics" brand tool I purchased at an auto supply store in an "emergency". I use it to remove bushings and sometimes for a tailpipe. It would not remove a big rivet tho. The tools it came with are not very high quality steel and do not remain sharp long. I have used higher quality units but I have no idea what kind they were.
Old Oct 29, 2004 | 02:08 PM
Mike W's Avatar
Mike W
They work great for punching thru asphalt. I planted some trees and used the chisel to cut thru a circle and then pulled out the center.
Old Oct 29, 2004 | 03:11 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
What kind of rivets?
I know in thin sheet metal, an air chisel will "walk" pop-rivets through the metal, elongating the hole
I have an air chisel, and while the bits are not the greatest in the world, I used it to cut up a Triumph TR7 into pieces for scrap with one of the special forked types.
If you are talking about rivets like what held on the spring perches on my '74 F250 frame, well, I don't think a small air chisel is going to do much, and again, you risk making the hole in the chassis oblong because beating the rivet made of steel will certainly mar the hole in the chassis made of steel.
I had some luck using a torch on my '74, but that was only to blow away enough of the head of the rivet to then grind it down and punch it through. My air chisel did nothing to them. Maybe a bigger air chisel would do it but it would beat the snot out of the hole.
Old Oct 29, 2004 | 07:55 PM
uk1050's Avatar
uk1050
yeah they work great for rivets. on the frame of my 53 i had plenty of revits
to cut out , i have a porter cable from lowes and it works great.
Old Oct 29, 2004 | 08:55 PM
rebocardo's Avatar
rebocardo
If you have a big enough compressor and big enough hose, then a big air hammer with a quality chisel will take the head of a rivet right off. But, this is not the best use of an air hammer. What you should do for a rivet is grind the head off, drill a 1/4 hole down the middle clean trhough the other side, then knock it out with an air hammer. That leaves you a nice clean hole for the bolt.
Second best method is have someone with a torch cut the rivet head off. I was not that good with the liquid wrench, but, on a TTB I easily heated the heads, blew them off, and then punched the remains of the rivet out with a punch and hammer.
fdude64
Jul 31, 2012 09:19 PM
RawPower
Offroad & 4x4
61
Mar 5, 2006 06:20 PM
datchew
16
Mar 18, 2005 01:54 PM
Divelong69
1983 - 2012 Ranger & B-Series
May 11, 2004 09:13 PM
TheImpaler
Paint & Bodywork
May 16, 2003 02:53 PM
