Destroyed pilot bearing
Old May 9, 2004 | 10:50 PM
Divelong69's Avatar
Divelong69
Talking Destroyed pilot bearing
Ok guys, here goes, just went through the destoyed pilot bearing syndrome... you know, the how do i get it out now thing... far too mangled for the grease trick, puller wouldn't even take it out! Here goes, found just the thing, if you have air(compressed), if you, or a buddy, has an air chisel, use the chisel for removing sheet metal, you know the one that looks like a flat chisel that the center is broken back on, insert the tooth side against the crankshaft, being careful to run along the shaft, not digging into it, this will remove a slice about 1/8th inch from the bearing race, taking all of the tension out of it allowing you to remove it with your finger, better news, if you dont have air, this chisel will work just as well with a hammer, be sure to remove all traces of shavings before installing your new pilot bearing, enjoy.
Old May 10, 2004 | 08:16 PM
Dealford's Avatar
Dealford
Welcome to FTE.
Creative use of tools... ...
Old May 11, 2004 | 09:13 PM
Divelong69's Avatar
Divelong69
Thanks, anything in a pinch, as long as it is a step forward, not back.
Ex03AK
Modular V10 (6.8l)
Dec 26, 2009 08:58 AM
66_in_ky
Sep 6, 2008 12:32 AM
JDMick
Mar 11, 2006 09:30 AM
datchew
16
Mar 18, 2005 01:54 PM
John Boswell
Jan 10, 2003 05:16 PM
