Transmission Identification
Old Oct 28, 2004 | 12:32 PM
IrieEye's Avatar
IrieEye
This question might be kind of remedial, but how do I tell what kind of transmission is in my '91 F150 4x4?
Old Oct 28, 2004 | 01:04 PM
bigboytoys65's Avatar
bigboytoys65
Look at the sticker on the driver's side door jamb. Under TR there will a letter--which corresponds to the tranny you have.
U – Automatic 4R70W
E – Automatic E4OD
M – 5 speed manuaoverdrive
Old Oct 28, 2004 | 01:43 PM
IrieEye's Avatar
IrieEye
I should have been more specific. I have a 5-speed manual, but I'm wondering who manufactured it. Borg-Warner or not?
Old Oct 28, 2004 | 04:12 PM
larry derouin's Avatar
larry derouin
Probably a M5OD (Fair to Middlin) made by MAZDA! Check the crosshatch pattern. If it's a vertical/horizontal pattern it's a M5OD. If it's diagonal it's a ZF (Better).
Larry
Old Oct 28, 2004 | 11:57 PM
optikal illushun's Avatar
optikal illushun
dont think the ZF made it into any f-150s after 89 and they were rare. 99% chance says its the mazdog...M5OD
Old Nov 1, 2004 | 05:22 PM
IrieEye's Avatar
IrieEye
Thanks for the help.
With the mazda tranny, should I be able to find a bleeder screw on the internal (cocentric) slave cylinder?
Or do I have to open up the transmission and replace to whole cylinder if my hydrolic fluid needs to flushed?
Old Nov 1, 2004 | 09:35 PM
dorymate's Avatar
dorymate
clutch flush
You dont need to remove anything. Just open bleed screw attach a hose to bleeder and continue to fill up the master cylinder until you get nice fresh brake fluid. After finishing the bleeding process you will have removed 99% of the old fluid.Best of luck.
Old Nov 1, 2004 | 09:59 PM
Chuky66's Avatar
Chuky66
What is the door code for the ZF 5spd on a 89 150 or 250? Did they put the mazda 5spd behind the 351's in the 150 or 250 trucks?
chuck
Old Nov 1, 2004 | 10:00 PM
peppy's Avatar
peppy
If you do have the M5OD.....might want to read this article.
purecty
Sep 17, 2011 05:09 AM
82f-100
Aug 2, 2010 07:51 AM
erica
Mar 20, 2004 11:15 PM
Leland
Apr 21, 2002 10:59 AM
pacific
Aug 4, 2001 07:28 PM
