98 expy runs rough after plug change
As it's a 1998 4.6, it uses two coils, each powering four plugs. The 4.6 didn't go to coil-on-plug until 2000. That said, what brand of plugs did you use? Tritons are a bit finicky about plugs, with more than a few people on this board having issues with non-Motorcraft plugs. Did you reuse the old spark plug wires? They may have been borderline before you pulled them off the old plugs.
I had a similar problem when I changed the plugs on my 97, 4.6. The wires were original and after being on so long, they were seized on the end of the plug, so when I removed the wire, something broke, and then I didnt get a tight fit and after a short time, it ran rough, check engine light came on. Scanned for codes and said problem with #3. Kept snugging plug wire back on, but after a couple of times of same problem bought the new wires and problem solved. Worth checking.
I reused the original plug wires and use Motorcraft plugs. The truck is running fine now, but with the check engine light. I will get to Autozone this weekend to get the scan codes. I am leaning towards the plug wires, because they were hard to get off. I also have to look at the PCV hose. When I changed the plugs, I did it one at a time. No chance of messing that up (I have done that before what a headach). Thanks for all the input. On another note, it seems to me that the ac compreesor is running all the time. I get water dripping from the front and rear whenever the controls are on. Any suggestions?
Thanks
Dean
Thanks
Dean
