Expanding pipe
Old Oct 27, 2004 | 10:02 PM
4x4bronco92's Avatar
4x4bronco92
Expanding pipe
Can anyone tell me where to get a tool for expanding exhaust pipe? Does Pep Boys rent the tool needed? Is it a fairely easy procedure? I would like to custom make my system if possible.
Thanks
Old Oct 27, 2004 | 10:40 PM
Pikachu's Avatar
Pikachu
Ya know, I used to see those tools at almost every parts store, but I don't remember seeing one in quite a while now. You might check with NAPA, though.
Old Oct 28, 2004 | 03:29 AM
jkorreck's Avatar
jkorreck
I've seen them at Harbor Frieght
Old Oct 29, 2004 | 12:37 AM
97Centurion's Avatar
97Centurion
Rub my Belly
I had to order one threw O'Riely. Advanced had some in stock but they were the cheap ones.
Old Oct 29, 2004 | 02:08 AM
Rancheroracer's Avatar
Rancheroracer
I bought a set at Harbor Freight
Old Oct 29, 2004 | 06:54 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Exhaust pipe stretcher
4x4Bronco, Lesle tool company has a "Exhaust Tailpipe Stretcher" that you use an impact gun on the bolt to expand. Don't get the tailpipe straightner as it only removes U bolt clamp crush, and not even good at that. The tailpipe stretcher bolt goes into a long nut that has 4 taper sides on one end to expand the shoes. Since i'm an electrician i added a hydraulic knock out punch to the expander, makes a trick tool to use. The Lesle Stretcher part # is LIS 34400, list for $107, can be had for $71 plus freight. Yes not cheap for a
tool that you don't use every day, but when i needed it, it was worth way more than the frustration of not having it. Man can never have too many tools, wives yes! Hope this helps, Carl.....o&o>......
GoldCo
Mar 22, 2017 10:23 AM
DerekShiekhi
General Automotive Discussion
Nov 24, 2015 05:56 AM
ReBilld
49
Mar 13, 2012 02:37 PM
cmachk
Oct 12, 2007 07:39 PM
dhhf64
Exhaust Systems
Apr 7, 2004 06:27 AM
