Making a new headliner?
Old Oct 27, 2004 | 06:03 PM
brisco's Avatar
brisco
Just took mine out and it needs to be replaced. Anyone here ever made one? I got the old one in one piece I could use to trace an outline, I guess.
Old Oct 28, 2004 | 01:34 PM
The67Beast's Avatar
The67Beast
That's not a bad idea if your not worried about it not being factory original. What would be nice is if after you cut out a new one, have it upholstered. That would certainly be different.
Old Oct 28, 2004 | 02:58 PM
BigBloo's Avatar
BigBloo
This is what I did when I restored my '69- I used the old one as an outline to cut the new one. I used a piece of the thin wood that folks used to put on their walls in the '70's-bought it at Lowe's, I then bought some black vinyl at Hancock Fabrics, bought some black furniture tacks, and automotive grade spray adhesive. Check out my gallery, I think I have a pic of it--it turned out pretty good and everything cost me less than $50...
Old Oct 28, 2004 | 03:27 PM
stormchaser70's Avatar
stormchaser70
Thats nice Bloo. I am currently in the same position of cutting a new headliner. I was just stuck on materials... I guess Home Depot/ Lowes will lead the way
btw, i have my speakers mounted like you do above the back of the bench seat. I highly recommend it to anyone who is not taller than 6 foot.
Old Oct 28, 2004 | 08:45 PM
baitmaster's Avatar
baitmaster
Did the same to mine, although I used 1/8" fiberboard, not wood. Had bad luck with hardware store spray not sticking, so went to upholstery shop and got the good stuff.
Old Oct 28, 2004 | 09:27 PM
mouse777's Avatar
mouse777
Allgood info as usual. For my bit, I saw a 60 a while back that was done with the 1/8 luan plywood as mentioned before, but was stained and varnished. Not original, but I was impressed and thats what I plan on doing when the time comes.
Old Oct 29, 2004 | 02:16 PM
BigBloo's Avatar
BigBloo
Thanks storm-I'm 6 foot tall and my head just BARELY clears the speaker--but they are out of the way, and you can hear 'em really good!
Old Oct 30, 2004 | 10:32 AM
7DF250's Avatar
7DF250
I had mine done by a friends dad who is a body man. He used a thin shhe of aluminum (I think) he said it was a PITA but he added Dyna mat and covered it in black vinyl. I was able to attach my CB overhead wich is why it fell apart in the first place. It will last forever I'm sure.
Old Oct 30, 2004 | 09:07 PM
19felix69's Avatar
19felix69
i dont know if alot of you have ever heard of "beadboard"...it is a sheet of wood with a round "bead" milled into it. it is usually used in high(er) end new homes around here in bathrooms and offices. i am making a headliner, door panels and a glovebox out of it. i will post pics when it is done. http://www.oldhouseweb.com/stories/Detailed/842.shtml
Old Oct 31, 2004 | 07:04 AM
dotcentral's Avatar
dotcentral
The original headliner is cardboard. When using thin plywood and luan, any difficulties getting it to fit right? I realize the stuff is flexible, but wondering how well it conforms at the corners.
My existing headliner is intact, but sagging. Not sure if I want to buy a new one from one of the vendors, or build my own.
How hard is it to take the sag out of my old headliner? If I'm going to cover it with fabric anyway, it wouldn't matter if the cardboard is stained. Main thing would be that it doesn't sag down again.
Old Nov 1, 2004 | 07:14 PM
getuted's Avatar
getuted
i used a sheet of 3mm mdf board, it works great........ so far
Eric Kropp
Dec 14, 2014 02:16 AM
bigwin56f100
2004 - 2008 F150
Nov 10, 2014 04:55 AM
1982_f150
Oct 23, 2014 02:23 PM
wallsy
Australia Chapter
Mar 12, 2014 02:55 AM
Luch
21
Dec 2, 2013 02:21 PM
