making a short bed
Old Nov 1, 2004 | 09:22 PM
arsetard's Avatar
arsetard
i think long beds look gross when theyre slammed onto the groung like mine will be.
Old Nov 1, 2004 | 11:08 PM
mlf72f250's Avatar
mlf72f250
To make it really gross, someone could put a standard cab on a crew-cab frame and stretch the box to match the frame. (Where's the barfing smiley face when you need one?)
Old Nov 2, 2004 | 12:36 AM
RR4E's Avatar
RR4E
hes talking about keeping the long wheel base but shortening the over hang in the rear.
The main problem I see here is the tail end dragging. Adding a suspension lift and mild body lift would cure this problem. It's a lot easier to do than shorten a body, and still make it fit on the frame. Anything done to achieve this will have to be behind the rear axle, not in front of it.
Old Nov 2, 2004 | 12:44 AM
arsetard's Avatar
arsetard
not be be an *** or anything but seriously read before you post he already has a suspension and body lift. and all the shortening he wants to do would be behind the axle. like i said he wants to keep the longer wheel base but he wants to shorten the rear over hang. and if you measure correctly you should have no problem getting everything to fit.
Old Nov 2, 2004 | 12:58 AM
RR4E's Avatar
RR4E
Pardon me. I just noticed the lift kit information. Thank-you for pointing it out.
So we're looking at shortening, fine. You'll have to shorten the frame front and rear of the axle, move the axle up, and shorten the bed accordingly. Hope you're good with a mig and bondo. Would be an interesting project to do. The bigger tires should help out a bit. I'd try a slanted forward bumper, or a tube style bumper first as well. It may drag still(depending on angles) but not have near as much drag.
Old Nov 2, 2004 | 01:40 AM
Vern69's Avatar
Vern69
Buy a shorter truck. That's the deal. If you wan't a truck with half the hauling capacity then that's the way to go. Period. If you can't put a full sheet of plywood (sheetrock, whatever) in it then it's not a truck. -JMHO!
Old Nov 2, 2004 | 01:46 AM
arsetard's Avatar
arsetard
i dont really care about hauling capacity. even if i liked long beds i wouldnt have much space with the 10" frame notches and the tubs and the fuel cell. all i care is that i can put a couple bikes (bmx) back there. id buy a short bed but i can buy a long bed and make it a shortbed for cheaper.
Old Nov 2, 2004 | 01:57 AM
RR4E's Avatar
RR4E
If you really want ground clearance, don't care what you haul, and don't want the back end dragging. Pull the box, sell it, and build yourself a flat-bed out of channel iron and tube steel. You can add stakes to add remove-able sides, or a head-ache rack with side bars, etc...the world is your oyster here. And be able to get rid of the rear drag, and make the truck as short as you want. I did this with a 69 Ford 4x4 when the box was to rusty to bother repairing, and also to expensive to bother with new/used parts. Add stacks(exhaust) and you've got yourself an interesting hauler. I used the channel iron(mounted inset marker lights inside the channel) tube steel to brace it as well as attach to the frame with 4x4 wood blocks for spacers, had the head-ache rack, side rails matched the bump side body-line, had to move the bumper up a bit, but it did the job real well. A deck is the most versatile bed, providing you build the stake-side features into it as well. Can be used for anything, and made how you like it. Probably easier than modding the existing box.
Old Nov 2, 2004 | 02:06 AM
arsetard's Avatar
arsetard
ill stick to cutting the existing box. because i want to drag.
elbono
Jul 15, 2025 09:42 AM
woodsmoke
Jul 22, 2010 09:53 PM
Ireland92834
Car/truck Buying Advice
Mar 13, 2010 09:07 AM
Norvous
All Things Towing
Jul 23, 2007 04:31 PM
Cur Dog
Jul 15, 2005 10:41 PM
