1994 EXPLORER auto trans
Old Oct 25, 2004 | 07:09 PM
69commander's Avatar
69commander
Hi
My EXPLORER has a little problem, It won't down shift from OD to first gear
it stays in second and when you start out it will shift to first after about 20 feet. This is a strain on the old thing so we drive it in drive instead of OD. It shifts fine in drive no problems. No slipping or burnt oil. What tells it to down shift 1994 isn't suppose to have a electronic board in the trans. It's not the converter staying locked up. Any help?
Old Oct 25, 2004 | 10:39 PM
daerhldgs2's Avatar
daerhldgs2
you have a problem in your valve body, try changing the fluid and filter as you may have a tiny piece of crud in the wrong place.
Old Oct 26, 2004 | 11:24 AM
69commander
Thumbs up
Thanks for the help
NM3
Jul 19, 2022 08:36 PM
relentlessmx
25
Jul 14, 2021 06:46 PM
TheJoblin
1983 - 2012 Ranger & B-Series
Oct 22, 2015 09:41 PM
relentlessmx
Dec 20, 2008 02:14 PM
PatL
Nov 13, 2001 05:21 PM
