PSD Scanner
Old Oct 24, 2004 | 07:09 PM
77hiboyboy's Avatar
77hiboyboy
PSD Scanner
Anyone know of a scanner to read codes on a 00 PSD. I hate all the stealerships around here, and have a good source on ford parts at a reduced rate, so will a programmer/tuner like predator read codes??
Old Oct 24, 2004 | 08:29 PM
MobeyDick's Avatar
MobeyDick
Snap-on makes one!!
Old Oct 27, 2004 | 10:18 AM
watersurgeon's Avatar
watersurgeon
Most AutoZone's will read the codes for free, for you.
Old Oct 27, 2004 | 11:37 AM
kmill35's Avatar
kmill35
Go to diatek.com. They make an afordable scanner that reads only ford. It also does all the other functions and reads data. Great for self diagnostics.
Old Oct 27, 2004 | 02:30 PM
77hiboyboy's Avatar
77hiboyboy
not an autozone within 200 miles though.
Old Oct 27, 2004 | 09:20 PM
watersurgeon
I don't know if this will work but try the Dash Board read if your mileage and trip odometer is digital display. Push in the mileage reset button and hold it in and then start the truck. I know on the 2003 this will default to a self diagnostic and you can click through every single code.
Old Oct 28, 2004 | 12:25 PM
mjwhip2's Avatar
mjwhip2
I use an Edge Evolution tuner ($300) When I was having tranny problems the shop hooked the truck up to their $12k snap-on and we got the same codes. So I was happy with my purchase.
Mike
Old Oct 28, 2004 | 12:34 PM
CLK's Avatar
CLK
The Hand held programmers like the Superchips and an Edge Evolution will both read codes form your truck, I like the superchips a little better it has a more comprehensive list of codes. There aren't many other readers out there that will read from these trucks unless you want to spend a chunk of change although Auto Enginuity makes one that will load into a lap top or palm pilot that will do all of the same tests that dealerships and the expensive diag. readers will do.
Old Oct 29, 2004 | 12:45 AM
TheCamel's Avatar
TheCamel
From what I understand, the AutoZone units do not read the "enhanced" codes that are used on Ford diesels.
Old Oct 29, 2004 | 11:53 AM
BigBadJohn's Avatar
BigBadJohn
That's correct. I had the flashing O/D light one night and Autozone couldn't pull a code. I went to a private shop with a more complex scanner who was able to pull the code. (BTW, it was a pcm code which ended up being low voltage from a faulty alternator)
John
evergladesgator
Nov 12, 2016 08:58 AM
Mdavidson1974
Oct 18, 2016 06:24 PM
95PSDNewbie
Apr 23, 2016 05:15 PM
martinkjc
Apr 25, 2012 06:52 PM
PastorPaul
Jul 26, 2010 10:29 PM
