Offroad & 4x4
brakes lockup
Old Oct 24, 2004 | 10:21 AM
muddyford75's Avatar
muddyford75
brakes lockup
went wheelin yesterday and now my back left and manybe right lockup when i tap the brakes. I am guessing its prolly just mud and stuff in the drums its a 78 f250 and tricks on fixing this. also when i hit hte brakes pretty hard the truck pulls left. whats my problem and what do i need to do to get this fixed
Old Oct 24, 2004 | 12:01 PM
proeliator's Avatar
proeliator
Yes, you probably have crap in your drums. Pull, clean, & repeat. If you really hate doing this convert to disk brakes. Less weight, better stopping, and self-cleaning.
Old Oct 24, 2004 | 03:46 PM
muddyford75
how do i remove my drums(back), I took the tire off and the big drum does not just slide right off do i have to take the hub off and everything or should it just slide off once tire is off.
Old Oct 24, 2004 | 08:17 PM
bremen242's Avatar
bremen242
you have a '75 with a full-floating dana axle, you'll have to pull the axle and take off the spindle nut.. bummer...
if you have a 1/2 ton axle, it should just pull off.
Old Oct 24, 2004 | 09:23 PM
proeliator's Avatar
proeliator
Yea, should be a D60 like Bremen described. Its actually pretty easy. You're supposed to have a special socket for the spindle nut but a couple good taps from a screwdriver and hammer will usually spin it right off too.
Old Oct 24, 2004 | 09:26 PM
JeremyH's Avatar
JeremyH
On older vehicles, the drum will likely be rusted to the shaft. It just need a little coersion (read, 3# sledge). Tap it arond the outer edge of the drum from all directions...it will slide off eventually. I pull and clean my drums about once a year. Brake parts cleaner does a good job......but make sure you put a bucket below to catch all of the crap....it'll make a nice mess in the driveway.
Old Oct 26, 2004 | 12:37 AM
highboy1975's Avatar
highboy1975
i like compressed air for getting rid of all the brake dust, just make sure you wear a mask so you dont inhale the stuff
Old Oct 26, 2004 | 06:19 AM
bremen242's Avatar
bremen242
brake cleaner is a bit safer buddy
Old Oct 26, 2004 | 06:48 AM
teds74ford's Avatar
teds74ford
Also, see if you chewed up your seals. If they leak, the tires could lock up. They are on the drum when you take it off, so they will be easy to change then.
mototrig
23
Mar 8, 2014 10:39 AM
Jeepincj7
17
Feb 17, 2014 10:31 PM
dabigac
1978 - 1996 Big Bronco
Nov 13, 2003 07:04 AM
ftrucktough
Mar 3, 2003 07:04 AM
