Stock Cam Specifications
Old Oct 23, 2004 | 11:50 PM
WillyB's Avatar
WillyB
I am building a chart showing the different cam timing - does anyone know the specifications for the stock 390 2bbl cam? Or can you point me in a direction where I can find out for myself?
Old Oct 24, 2004 | 07:14 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
What year 390? I have six cams listed for 66-71 390's 2v. G.
Old Oct 24, 2004 | 07:15 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
BTW if you have the Steve Christ book "How to rebuild big block ford engine" there is a chart on page 85 of all the cams and specs. G.
Old Oct 24, 2004 | 11:58 PM
ford390gashog's Avatar
ford390gashog
what about a 69 2v
Old Oct 25, 2004 | 01:17 AM
WillyB's Avatar
WillyB
69 2v works for me, or a 72. Christ's book gives the lift, but not the opening and closing. I see he lists a 390 2v and 4v for the pickup years 1968 through 1976. That one would be ideal as it is the one most of us have stock.
Crain Cams gives their opening and closing at 0.004 in and the industry standard 0.050 inch. I would like to be able to compair these numbers with the stock cam.
Old Oct 25, 2004 | 04:25 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Valve spring specs are pg 110.
Old Oct 25, 2004 | 06:33 AM
WillyB's Avatar
WillyB
Thank you - I had not considered the valve springs - are you saying that the higher lift performance cams compress the springs more, or require stiffer springs, and therefore take more power to operate?
Obviously they add more power than they take, but would there be an economy hit when you go with a performance cam that needs to be accounted for?
Old Oct 25, 2004 | 04:33 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yes, if your replacing your cam with a new one. Most cam's have matching springs that are recomended by the company. As long as your within the specs of the factory spring ratings with your new cam stock replacements would be fine. But most cams today are higher lift and duration with smaller lobe centers so check carefully. I can't really comment on economy. Perhaps someone will chime in and offer their input on a nice street cam that's economy minded. I've always gone for power myself. G.
crsweet78
23
Mar 26, 2024 04:31 PM
Jklnhyd
May 17, 2016 09:17 AM
cfrives3
1978 - 1996 Big Bronco
May 21, 2007 06:03 PM
Boss Machine
Dec 20, 2006 01:08 AM
oldblue31
May 21, 2005 08:13 PM
