Not starting - Help!
Old Oct 22, 2004 | 07:02 PM
jwjeep's Avatar
jwjeep
I've got a '00 4.2 that has been a great truck. I climbed in this morning, turned the key, and nothing. I can start it by jumping the selonoid, and it runs fine, just doesn't even try to crank. Is it the switch on the clutch rod? Is there another switch? How do I tell, there's so many wires going to the switch on the clutch rod, I wouldn't even know where to start. Any help would be apprediated.
Old Oct 24, 2004 | 08:33 PM
rmanTX's Avatar
rmanTX
jumping the solenoid? like closing the circuit on the starter?
Old Oct 25, 2004 | 07:53 AM
Busa01's Avatar
Busa01
I used to have to do that on my old Plymouth Road Runner. I think I had my whole starter replaced but It's been so long, I don't quite remember.
Old Oct 25, 2004 | 09:38 PM
rmanTX's Avatar
rmanTX
Hmmm....
Have you tried having someone turn the key while you bang on the starter with a hammer or crowbar? When starters go out, they start to freeze up. If you bang on it while the key is turned, it'll either start up or try really, really hard to start up. If that's the case then you need a new starter. But since you can jump it then hmmm....
Try a little elbow grease with club soda, it'll take it right out...
Old Dec 6, 2004 | 07:29 PM
97 bryan's Avatar
97 bryan
Thumbs up need to rethink
Sound like a ignition switch to me its not the starter if all you have to do is jump the power across to closs the circuit. good luck!
Old Dec 7, 2004 | 11:09 AM
fplorer's Avatar
fplorer
Could be a solonoid also. Have someone turn the key to start and see if you have 12 volts at the solonoid S terminal. If you do it is a bad solonoid. If you do not, you need to look at the clutch switch or the ignition switch.
MrGoodnuts
Jan 3, 2023 01:01 PM
KelsterB
British Columbia
Dec 26, 2014 02:19 PM
amthatiam
Jun 2, 2012 12:42 PM
1wicked90lx
15
Jan 24, 2010 06:19 PM
dstevenson
Electrical Systems/Wiring
Jun 1, 2003 10:35 AM
