Cluth pedal switch remove and replace, how?
Old Jun 2, 2012 | 09:49 AM
amthatiam's Avatar
amthatiam
Hi everyone,
I need to know how to remove and install the clutch switch from the rod that goes to the clutch master cylinder. Thanks in advance for your help.
Dan
Old Jun 2, 2012 | 10:02 AM
amthatiam's Avatar
amthatiam
forgot to mention
I forgot to mention that it is a 00 F350
Old Jun 2, 2012 | 10:20 AM
mueckster's Avatar
mueckster
Here ya go.
Clutch Pedal Position Switch R&I.pdf
Old Jun 2, 2012 | 10:40 AM
F350-6's Avatar
F350-6
Pretty much you just have to stand on your head, use a flash light, and cuss at it. The bottom of the CPP is actually a u-shaped piece. You have to reach up on the sides of the CPP and spread the bottom piece apart to pull it off.
A small screwdriver helps. You can pull the CPP back toward the seat a little. When you do, you're able to rotate the CPP around on the shaft so you get a better angle at it.
Old Jun 2, 2012 | 11:22 AM
mueckster's Avatar
mueckster
Aw. Come on now, Chris. You ought to be an old hand at this by now.
Old Jun 2, 2012 | 11:29 AM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Roland, he has done so many times, thats how he learned to cuss.
Old Jun 2, 2012 | 12:42 PM
amthatiam's Avatar
amthatiam
Thanks guys,
amazing what a little light and glasses does, I got it apart, easy really once I could see. I was replacing the clutch pedal and it's mounting bracket and that was the first thing I stumbled upon. Master cylinder and that rod were a bit of a btch and I got through it.
This truck never shifted so good, the old one the fulcrum pin had worn so far into the aluminum that I couldn't shift anymore.
Thanks again.
Dan
J5BAIL
1997 - 2003 F150
Sep 23, 2013 03:40 PM
bigreddieselco
Mar 8, 2009 05:05 PM
Tofudi
Apr 9, 2007 07:21 PM
4x4man514
Aug 30, 2004 07:19 PM
