compression test
Old Oct 22, 2004 | 01:26 AM
72ford360's Avatar
72ford360
compression test
i did a compression test today on my 72 ford f250 with 360 fe.i got 125psi in every single piston .also with the throttle closed.seems kinda low but i know this engines came with low compression.what kind of #s have you guys gotten.
Old Oct 22, 2004 | 03:03 AM
longview1's Avatar
longview1
Banned
When i did a comp test on my 360, last time, The highest I got was 140, Then mainly arond 125ish-135ish. (not to mention a 90 and 75 )
Old Oct 22, 2004 | 08:08 AM
EgoMan's Avatar
EgoMan
That is fine compression for a 360....Mine had 90-100psi and has run great like that for 7 or 8 years now.
Old Oct 22, 2004 | 11:10 AM
72ford360's Avatar
72ford360
Thumbs up
alright!!!seemed a little low but i was surprised every piston got the same.thanxs guys.
Old Oct 22, 2004 | 11:32 AM
yomow's Avatar
yomow
When doing comp. test pinch incoming fuel line to fuel pump & remove hot lead from coil . open throttle WIDE open - crank engine the same amount of turn's or for so many sec.'s do it w/ the engine cold, & - running temp., this will give you a base line on your engine's life for it's power .
Don
pollock
Feb 20, 2021 07:42 PM
enrand
Apr 1, 2017 06:14 PM
marshallstanford
Jul 15, 2016 06:42 AM
krazyness
Feb 25, 2016 09:09 PM
bdk731
Aug 20, 2015 08:33 PM
