engine starts but dies
Old Oct 21, 2004 | 03:45 AM
hellraiser6918's Avatar
hellraiser6918
i have a 1979 f150 with a 302. i was coming home and i just put 10$ in gas in and while i was driving the egine started dieng like it was out of gas i looked at teh gauge and it was half full so i pulled over and it was dead. i started it and reved it and drove like a block and it died so i push it into a parking lot. messed with it for a little bit and only can get to run and higher rpm if i feather it. but when i let of it sputters and dies. it was dark and cold so i walked home and ill get it tommarow to bring it home but do any of you have any idea what could be the cause. thanks for any help
Old Oct 21, 2004 | 10:42 AM
mleichtle's Avatar
mleichtle
I'd say its not getting enough gas. Your symptoms sound similar to mine, I got a plugged gas line or tank.
Old Oct 21, 2004 | 11:01 AM
hellraiser6918
well i suspect its a carb problem because i went back with some carb cleaner sprayed the carb a few times finally got it to run and got it home. but i did also play with the ignition module (unpluged it plug it back in and played with the wires) but i dout that was the cause. im going to rebuild the car and see hope this doesnt happen again
Old Oct 21, 2004 | 01:22 PM
stinkinlinkin's Avatar
stinkinlinkin
Maybe I am thinking too simple, but what about the fuel filter?
Old Oct 21, 2004 | 05:20 PM
hdgapeach's Avatar
hdgapeach
Big vacuum leak, fuel pump going south, fuel filter clogged, ten dollars of bad gas, trash in tank clogging pick up. (Just a few to start with)
Old Oct 22, 2004 | 10:26 AM
hellraiser6918
it cant be the pump cuz when a mechanical pump goes it goes it doesnt realy go and come back and go again. i got it to run and going to work last night it started it again and coming home from work this morning it was working. it could be somthin in the tank, it could be the filter and the vaccum is good. im going to try rebuilding hte car since that costs like 15 bucks and put a new filter on it while im at it.
hellraiser6918
hellraiser6918
motoxxman
13
Oct 30, 2012 10:21 AM
cam4x4
32
Jul 31, 2011 08:56 PM
ech0sh4y
50
Dec 30, 2007 01:28 PM
Nick19894X4
May 13, 2007 06:12 PM
Trialsguy
Bronco II
22
Nov 10, 2004 10:26 AM
