I got a 4-way emergency flasher from a 65 custom cab at the local auto wrecker. Does anyone out there have directions showing how I can install these 4-way flashers into my 65 custom cab? Thanks George
jcs...I have a handle w/red light in it...heavy cast piece....I thing out of some GM rig...
Can...if you removed the setup from the truck, then all ya need to do is go back and note which plug was where and so on...the main harness in these were the same...the extra harnesses...like 4 way flasher was simply plug and go....same goes for the extra gauges too....that one carries out under the hood to and includes the lil junction block assy. by starter relay....If you need more help, drop me an E as i got wiring diagram for it as mine is also a 65
I have a couple complete hazard flasher setups that I removed from parts trucks. The setup includes the switch, flasher, and red dash light and bezel. They have the harness that should plug right in. I did this upgrade on my 66.
