power steering groans
Old Oct 20, 2004 | 10:06 PM
jcab's Avatar
jcab
Angry power steering groans
Could anyone please tell me why my steering wheel groans on my 97 crew diesel 4wd? I've bled the steering system twice, seems worse after I bleed it the first time. The level seems fine to me, at least I think it reads where it's supposed to be. Could the power steering pump be going out slowly, the belt is tight. Stumped????
Old Oct 20, 2004 | 10:36 PM
Bluesbandit's Avatar
Bluesbandit
In my experience, Ford power steering pumps are just plain noisey. That doesn't mean you don't have a problem. Is the system bled properly? The fluid level correct? Leaks? I guess the seals or the pump might be going out, but you should see some evidence of that.
Old Oct 20, 2004 | 11:18 PM
jcab's Avatar
jcab
moaning and groaning
Thanks for the reply, the evidence I should see is ??? Stiff turning? Pulling to the right which it does, but that could be the tires, which need replaced. As far as bled properlly, I opened the top of the steering reservoir, had the wheel turned left to right, at least 5 minutes. Does fluid get old, and need replaced? Tell me if I'am doing something wrong, in bleeding procedure. Thanks again. Jeff
senix
Sep 19, 2015 04:47 PM
pspehar
Jul 26, 2015 07:37 PM
DeathRangerofDeath
Mar 1, 2015 05:43 PM
bkuuz1
Nov 28, 2014 06:09 PM
F250_
26
Nov 9, 2014 10:49 PM
