Bronco II Ford Bronco II
Headlight Issue
Old Oct 20, 2004 | 02:23 PM
MikeBroncoII's Avatar
MikeBroncoII
Question Headlight Issue
I am an owner of a 1988 Bronco II all lights work except front headlights-I checked fuses , socket connections all seem to be fine . Checked headlight bulbs and are okay. Brought to repair shop -they put in new light switch and still no headlights -they said no power to lamps ... they assume a lamp module defective however they need to take apart the whole dash board and still that may not be the problem - can you advise or please assist ? thanks so much for your help
Old Oct 20, 2004 | 05:43 PM
Help I M Stuck's Avatar
Help I M Stuck
If you can't find out what went bad where..just take and make up your own 12v supply conncection with a seperate off/on switch. I had to do this for an old truck i had once..just make sure to use a relay so you wont burn up the off/on switch.
Old Oct 20, 2004 | 08:13 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
On my 1989 the circuit is very simple. There's a BR wire providing power to the switch, check it 12v, if you don't have power there you may have a blown fuse in the power disrtibution box or blown fusable link. Then you should have power with the switch on at a R/Y wire which goes from the switch to the Hi/Lo switch, which is part of the multifunction switch. If you had power at the BR and none here it's the switch. At the MFS you should have power at a R/BK wire for low beams and power at a P wire for hi beams. Don't forget the grounds and thats it for the circuit.
yenrod
2004 - 2008 F150
Mar 15, 2014 05:47 PM
michigan66
1983 - 2012 Ranger & B-Series
Jan 12, 2013 07:38 AM
F250racer
Feb 5, 2009 10:23 AM
Beastmaster
Electrical Systems/Wiring
Jan 24, 2006 12:13 PM
Munkey
Oct 21, 2004 03:54 AM
