Headlight switch indicator lamp
Old Jan 11, 2013 | 02:39 PM
michigan66's Avatar
michigan66
Hi all,
I have been having an interesting problem with the indicator lamp(s) on my '08 Ranger. When I turn the light switch to either PARK or HEAD positions the indicator light usually only lights for the PARK position. Once in awhile the lamp(s) will illuminate all therr positions. I have checked the Ford factory shop manual for a clue and have had no luck in finding out what the problem may be. Is there only one lamp or are there 3 lamps in the switch assembly?
Any ideas or suggestions will be greatly appreciated.
Old Jan 11, 2013 | 05:22 PM
03 Maz B23's Avatar
03 Maz B23
My 03 only one bulb for the background illumination on the light switch which is what I assume you are referring to. Mine has burned out multiple times. It is wired to be on any time the engine is running regardless of whether lights are on or not. Stupid setup and the reason the bulbs don't last long. They may have changed it on your model year but would be surprise if they did.
Old Jan 12, 2013 | 02:01 AM
michigan66's Avatar
michigan66
To 03 Maz B23: How did you go about replacing the bulb?
Old Jan 12, 2013 | 06:26 AM
03 Maz B23's Avatar
03 Maz B23
There used to be a pictorial link on a website that have yet to locate. Here is a written explanation of disassembly to get to it. Once switch is removed the bulb is mounted in a circular assembly (with an X on it) that using a screwdriver you rotate counter clockwise to remove. Can either buy a replacement from ford or buy a grain of wheat type bulb from radio shack and wire in place of the original. After this last burnout think I will not mess with mine again. Some have converted the bulb to an LED . Since yours lights at times it may simply be loose in the socket.
note on and instructions for replacing the headlight switch bulb - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Old Jan 12, 2013 | 07:38 AM
03 Maz B23's Avatar
03 Maz B23
Here is a link with pics that shows dash disassembly to get to headlight switch. You won't be removing gauge cluster just the info up to that.
1995-Current Ford Ranger Gauge Cluster Removal
VSoldat
2004 - 2008 F150
Feb 6, 2019 08:49 PM
DaytonaTunnel
Jun 21, 2014 12:26 PM
07250psd
Mar 9, 2009 07:25 PM
zr440man
Jun 16, 2005 09:31 PM
4x4_EB_Explorer
Feb 21, 2002 10:19 AM
