Blower motor help
Old Dec 10, 2002 | 02:28 PM
rg0327's Avatar
rg0327
Post Blower motor help
I have been having problems diagnosing a problem with my fan motor in the heating/AC system. In late summer (with AC on) the fan/ac just up and stopped working. I replaced the 20 amp fuse (in D/S dash panel) to no avail.
Here is what I have checked / replaced.
New blower motor
New selector switch (which I broke trying to check points)
Fan does not work on any fan setting (eliminating resistor as culprit)
Fuse in distribution box is good
Relay (behind Pass side headlamp) functions properly
I get appx. 10 amps of power to the connector at the fan itself with the selector switch in the off position. Once I turn it to any other setting (vent/def/floor) I lose power. This is because the fan motor completes the circuit?
Any help would be great! I am running out of parts to check.
Old Dec 10, 2002 | 02:40 PM
mathelm's Avatar
mathelm
Blower motor help
Sounds like the heat diode (could be a cap) in the reostat (resistors). Tell me what year it is n I'll try ta tell ya what color wires cross to check it. Or better yet, Take the reostat out (leaving it connected) and short out the heat diode and with the fan on high. But don't leave it like that forever, the heat diode is there for a reason, keeps your truck from burning down. Last one I replaced I got at a junkyard for $5 bucks.
Hope this helps
Old Dec 10, 2002 | 02:56 PM
rg0327's Avatar
rg0327
Ok, I don't even know what that would be, so I guarantee that I haven't checked that. It's a '96 (4.0 if it matters).
Where would I locate the heat diode (what would it look like so I can try your suggestion? I'm fairly "green" when it comes to anything this involved so I REALLY appreciate your help!
Thanks again,
RG
Old Dec 10, 2002 | 03:35 PM
mathelm's Avatar
mathelm
Blower motor help
Ok, took some pics for ya
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=11153&.jpg
This is where its located on my 87. Yours maybe behind the glovebox or under the dash on the passengers side.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=11152&.jpg
This is the reostat out of a 91 tempo which I think is about the same. This is the one I experimented with and the heat diode is gone, but I drew one in so you'd get an idea of what it looks like. This is what you want to short (see arrows). I used a paper clip.
Hope this helps....
Old Dec 10, 2002 | 06:30 PM
rg0327's Avatar
rg0327
Blower motor help
Ok, one more piece of the puzzle that is working just fine. I jumped it like you suggested... nothing! I went out and got a Haynes manual since your last message and that hasn't given me much to go off of either. I have one more "test" to try with the blower switch itself, but I think it's a stretch at best. I'll keep you posted.
Thanks a ton!
RG
Old Dec 11, 2002 | 09:12 PM
mathelm's Avatar
mathelm
Blower motor help
Resolution: rg0327 emailed me to say he found a rusted and broken connection.......
Old Dec 11, 2002 | 09:33 PM
mathelm's Avatar
mathelm
Blower motor help
jtcdudeman
Sep 16, 2016 01:05 PM
j4wall
May 1, 2015 06:38 AM
Chuck Fuller
Mar 26, 2015 04:47 PM
mse871859949
Jul 4, 2014 07:33 AM
MikG
Jun 27, 2006 04:27 PM
