Blower quit, need help!
I have a 1980 f350 with a 400 and it's my baby I fricking love this truck. That aside, the PO converted the old AC to R134 and it works really well. Today I pulled into the auto parts store to fix my POS mustang, AC was blowing cold. Turned the truck off and when I came back the blower motor would not run. The AC works, but the fan won't turn on. It's lame.
Here's what I know. Fan will not run on any setting. The 30 amp fuse is good. The blower fan works fine (I hardwired it). I pulled the red resistor out and it looks good, not burned or anything. What should I check next? I was going to check the power to the resistor with a 12v continuity test next. If power is good to the resistor, it must be the resistor right? If there is no power to the resistor...would it definitely be the switch? Please help!
I would suggest checking your switch, most likely its not the thermal fuse. I only blew my fuse because I was jerking around....its a very long story involving fire. ha!
Keep us posted.
1) Go in cab, turn key on and turn blower on low.
2) meter across any 1 terminal and ground. One of those terminals should show power...in fact it should show a full 12 volts. (The resistor is what then drops the power...)
3) go back to cab and click switch up 1 click.
4) meter another terminal (one that isn't the one you found power on) to ground.
5) repeat until all switch positions are checked.
If you don't see power after step 2 then it's possible you may have a fuse blown. Check that at the fuse panel then repeat step 1.
Basically if you see power at any one of those 4 terminals that means the switch is working.
It's much more simple than it sounds. Late night and exhaustion makes for a not-so-concise explanation.
good luck
Motorcraft YH367 Pickup AC Selector Vacuum Valve
Found one for 35 and a resistor for 25. Not too bad considering...the time and frustration it took to diagnose the problem was a worse expense! Thank you for helping me out grandma!
