Build Date Question?
Old Nov 1, 2004 | 08:15 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by gmcbride
okay, so here is my number from the driver's side valve cover label:
1FMSU43P64EB11797
can anyone interpret this for me?
Thanks, gm
You first post 7/13 and never welcomed...
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
Enjoy FTE
Old Nov 2, 2004 | 03:11 PM
gmcbride's Avatar
gmcbride
thank you. maybe i misunderstand, but i did a search on the subject, found the appropriate thread (at least what i thought was the appropriate thread) and asked my question. yes, i have read both the documents you refer to, neither of which seem to answer my question. am i missing something here? thanks, gm.
Old Nov 2, 2004 | 04:01 PM
SBV45's Avatar
SBV45
More specifically, look at the second picture on this page:
http://dan.prxy.org/Truck/6L_bible_h.../Page_008.html
You will see a date with the day month and year like 27 Mar 03. In smaller print will be the plant where the engine was made. In the referenced picture, the top white label rotated left is the one you need to see.
The location is the FICM which is on the driver side toward the back. It is hard to see. I need to stand on a step stool, lean in under the hood while craning my neck and using a flashlight.
Also take a look at this page:
http://www.flatratetech.com/6literpo...oke/03or04.htm
Let us know.
Old Nov 2, 2004 | 05:25 PM
cdtruckn's Avatar
cdtruckn
the duke:
My 04 is the same, no date on the yellow tag. My 03 had the date on it.
Old Nov 2, 2004 | 07:20 PM
gmcbride's Avatar
gmcbride
okay, i was just being lazy and trying to get it off the valve cover. i can't seem to read the ficm label so i will have to be a little more aggressive to get to it. thanks,
99expy
Aug 29, 2009 07:19 PM
PsD007.3
50
May 5, 2009 10:42 AM
skidooF350psd
Mar 11, 2005 02:40 PM
gen-x
Nov 8, 2004 08:34 PM
Ford 2002
Car/truck Buying Advice
Apr 23, 2002 11:14 AM
