Barometric Pressure Sensor Pinout
Old Oct 15, 2004 | 12:34 PM
mr_muldoon's Avatar
mr_muldoon
Hi, does anyone know the pinout of the 2004 baro sensor??
Regards.
Old Oct 15, 2004 | 01:28 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Regards.
Hang tight for a while...Ill see if it is in the FMCdealer service archives when I get home
Old Oct 15, 2004 | 01:42 PM
mr_muldoon's Avatar
mr_muldoon
Just found it, but thanks for reply.
Old Oct 15, 2004 | 02:13 PM
Motown Fire's Avatar
Motown Fire
Regards.
So what is the Baro senso??? And what is the pinout?????????
Old Oct 15, 2004 | 04:31 PM
SBV45's Avatar
SBV45
Barometric Pressure Sensor. The Barometric Pressure (BARO) sensor is a variable capacitor sensor that processes a signal indicating atmospheric pressure. This allows the PCM to compensate for altitude. The PCM uses this information to calculate injection timing and glow plug control. The BARO sensor is located behind the lower steering column opening finish panel.
It is used in conjunction with
Accelerator Pedal Position (APP) Sensor
Analog Manifold Absolute Pressure Sensor
Camshaft Position Sensor
Cold Idle Kicker
Crankshaft Position Sensor
Engine Coolant Temperature (ECT) Sensor
Engine Oil Temperature Sensor
Exhaust Pressure Sensor
Fan Speed Sensor (FSS)
Injection Control Pressure Sensor
Intake Air Temperature (IAT) Sensor
Manifold Air Temperature (MAT) Sensor
Pinout is the wiring attached to the sensors and what the electrical value of each should be.
Old Oct 15, 2004 | 05:25 PM
Motown Fire
That one heck of an answer!!!! Thanks alot for the info.
mj_355
Oct 11, 2014 10:34 AM
w5kgt
Jul 15, 2014 10:14 PM
97puller
May 28, 2012 11:56 AM
quackrz
May 21, 2012 08:52 AM
workingdog
Jan 7, 2008 06:43 AM
