Ford Powercode vs Python Questions
I've also been considering the Python unit, the local Viper dealer turned me off on my first call, but the Python dealer was professional and asked the right questions about my truck. The 881xp was about 549 installed, the Ford unit would run about 400. I like the two way feature of the Python 881 but the dealer seemed to encourage the ones without the LCD. Is there any major difference between the Python and the Viper units? They appear identical and I've read the only difference is the marketing.
Final question, is I really hate hearing alarms go off so that is one reason I like the Pythons 2 way feature. Can the siren be deactivated and still keep the rest of the system operational?
The siren can be deactivated by not even hooking it up. Keep in mind that alarms that go off all the time are ones which were not installed and/or adjusted correctly. A shock sensor whose sensitivity is set too high is the usual culprit.
Here are some good links offering advice on alarms and car security in general...
http://forum.sounddomain.com/forum/u...c;f=9;t=001941
http://www.directed.com/security/sec...e/article3.asp
Recommended alarm systems...
http://forum.sounddomain.com/forum/u...c;f=9;t=002432
You may also want to peruse these auto security specific forums...
http://www.the12volt.com/installbay/...pics.asp?FID=3
http://forum.sounddomain.com/forum/u...?ubb=forum;f=9
