I need help, my 93' f-150 is acting up as of lately, every time I pull up to an intersection, or stop for that matter, the truck falls flat on its face, the engine surges and the voltage gauge peaks in the wrong direction, you know, 8 NORMAL 18 it usually sits on the L but in the last two or three days its moving towards the A, and today, its on the A about to the M.
Is this alternater or is it voltage regulator, or something completly different???
You have to decide what is happening first. Is the engine having trouble, which causes the alt rpm to drop and then the voltage to drop, or is the alt failing causing the engine to falter. I would lean toward the engine causing the problem unless you have noticed something else happening to consider the alt system being the culprit
it's the engine, it'll drop revs drasticly and as soon as it starts it'll send the gauge bouncing from side to side, and I'm not making it sound bigger than it is it literally bounces the needle from 18 to 8 back to 18.
Also, I went for a drive right after I posted and the needle is now to the M of NORMAL.
if you use the power windows or locks it'll bobble the needle along with dimming everthing involved with the truck, i.e. head/tail lights, radio, dash, blower motor, etc.
Anyway, what would the engine be doing to cause this??? I'm stumpped, because I've never had this problem with any other vehicle.
Just had a similar problem...my needle was "bouncing" also. When it bounced...my headlights would flicker and blower surged up and down....It was the regulator...went to the boneyard, grabed a decent altenator.......problem fixed.
This senario does sound like an alternator problem.
