Light Flicker / Surge Problem
Old Jan 20, 2007 | 08:02 PM
ORDuck's Avatar
ORDuck
I have a 69 F250 that, primarily when cold, seems to have a voltage flicker / surge, evident in the headlights, taillights, and dash lights. It's not related to RPMs - it just goes up & down at a rate of about once a second.
I'm not sure how to check the voltage regulator, and I understand there is a voltage stabilizer for the instrument panel. Any ideas on what the problem may be, or how to go about checking out the voltage regulator?
Thanks for any advice,
OR Duck
Old Jan 20, 2007 | 08:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B9MZ-10804-C .. CVR=constant voltage regulator..But the cvr is used to regulate juice to the dash gauges, and has nothing to do with the lights.
One of our fine troubleshooting electricians will be along to help you.
Old Jan 20, 2007 | 08:20 PM
Mil1ion's Avatar
Mil1ion
First thing to do is cleanup all contact points for the charging system
Unhook the battery cables and clean all terminals
Unhook connector to Voltage reg and clean terminals
Remove VReg from its mounting and clean the mounting contact areas and apply di-electric grease to prevent further corrosion.
Hook everything back up and check for that flickering again.
Corrosion on electrical connections on these trucks is running rampant.
Old Jan 20, 2007 | 08:30 PM
Dave Severson's Avatar
Dave Severson
Yuppers. I've found bad grounds and or bad connections to be at fault on a lot of intermittent and only when cold electrical problems.......
mkm43057
Sep 4, 2016 02:51 PM
Damifiknow
Aug 14, 2015 03:50 PM
mu2bdriver
26
Feb 16, 2014 01:33 PM
nathanstephanie
Dec 6, 2010 04:25 PM
hornsurgeon
Oct 8, 2009 05:13 PM
