Please help, poss elec issue??
Old Oct 14, 2004 | 11:23 AM
cubbiegrrl420's Avatar
cubbiegrrl420
Cool Please help, poss elec issue??
Hi
This is my first time posting on here
Vehicle: 1998 Explorer
About a month ago my 4WD HI and 4WD LO lights in the dash appeared and blink on and off for about 5 seconds every 10 minutes or so. I called the dealership and they think it is a big problem. Then I looked at all the fuses and one was loose so i pushed it back in and the problem stopped.
Now, for about a week it has been happening again. In addition, my headlights are not working. The daytime running lights, signals, parking lights and tail lights work fine but when I turn on the headlights they do not come on. I have checked the bulbs and replacing them does nothing.
Do I have a bigger problem here that needs to be checked out or could I do something myself. (My best friend has a lot more experience with mechanics but not electrical probs but can do a lot of other things)
Please help! I am a student and way too broke to take it in somewhere right now.
THANKS!
Old Oct 14, 2004 | 12:20 PM
MunsterGarage's Avatar
MunsterGarage
Did you pull that loose fuse out and inspect it? check all your fuses out first.
Old Oct 14, 2004 | 12:24 PM
Franklin2's Avatar
Franklin2
Yes, check for corrosion on the contacts and make sure the contacts in the fuse box are not spread open, making poor contact.
Do you have a "light out" monitor? Some guys on here have had problems with their headlights, and the light out module was actually causing the problem.
