EBPV not working?
Old Oct 18, 2004 | 05:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I have to disagree with you on this one. Since the valve puts backpressure on the engine, it helps to raise EGT. The primary purpose of the valve is to help warm up the engine, not the cabin air. Of course, when the engine warms up the cabin air also warms up.
It's cool. Somebody has to keep me on my toes. The following is quoted directly from the Ford service manual.
Exhaust Back Pressure Regulator
Exhaust back pressure is controlled to provide more heat to the coolant for cab heating when ambient air temperature is below 7°C (45°F) and engine oil temperature is below 75°C (167°F) during low load. At high load, high speed conditions, the back pressure system is disabled.
Old Oct 18, 2004 | 05:05 PM
johnsdiesel's Avatar
johnsdiesel
OK, you got me there, the primary purpose according to Ford is what you originally said, but isn't heat a direct result of a warmer engine? The backpressure valve will warm up the engine sooner and in turn you will have heat sooner, right? It doesn't directly give you heat sooner without warming up the engine first. Just my take...
Old Oct 18, 2004 | 08:55 PM
Kwikkordead's Avatar
Kwikkordead
Yes, it's purpose is to make the engine labor a little and make some heat to warm up the engine, heating the coolant, and in turn providing heat for the cabin.
Old Oct 18, 2004 | 09:43 PM
96ford4x4turbodiesel's Avatar
Originally Posted by mr_fixit
I had the same problem and found that I had a code telling me the backflow pressure sensor was bad. I always read 40 psi even when the truck was off. If the PCM sees a fault with this sensor it disables the valve.
im getting a code telling me that "exhaust backpressure sensor low input" p0472 i think, if this is the same code you got did you have to buy a new one or just clean that tube or what? it doesnt get that cold down here but during the winter i would like that valve to work just to get the engine warmer faster, just incase i got to get in a go. thanks alot
Old Oct 19, 2004 | 05:58 AM
mr_fixit's Avatar
mr_fixit
I wound up buying a new one which took care of it. If the pressure is low with the engine not running you need to check and make sure the witing is good and if so replace it. If you need to how I can give more help to troubleshoot.
Old Oct 19, 2004 | 11:42 PM
where is that sensor at?
Old Oct 20, 2004 | 05:47 AM
mr_fixit's Avatar
mr_fixit
Its right near the water pump housing on the front of the engine. You'll see a connector going to a sensor that is attached to a tube which goes to the the rh exhaust manifold.
Old Oct 20, 2004 | 08:04 AM
mtncrawler's Avatar
mtncrawler
And brace yourself when you go to buy a new one. Ford dealer gets about $150 bucks for that little sensor. After cleaning my tube (I'll buy a new one next time) my EBPV was still closing and causes an almost complete lack of power to the point where I could make only 20-25 miles per hour. This after 10 or 15 minutes idle time. Since disabling the thing I've had no problems.
Karruda
Nov 16, 2015 10:39 PM
xbox73
May 5, 2014 06:47 PM
mtnsammy
Feb 26, 2014 11:17 AM
Doucheatron
Jan 25, 2013 04:38 PM
Liquid10Rider
Dec 11, 2012 04:58 PM
