Fired up my PSD this morning, this is the first time since I've had it that it's been cold enough that it idled up on it's own. It brought itself up to 995 rpm(according to the APCM) but, the EBPV did nothing, tried unplugging it just in case my ears were failing me, and it did exactly nothing. In my prior experience with these trucks, it will idle up and close the EBPV together, and, I've never seen just the high idle alone before.
Do I have something amiss, or is this normal operation I just haven't seen before?
The idle can come up without the EBPV closing. It all depends on the ambient air temp and the oil temp. If when it gets colder out your EBPV still doesn't work then the tube to the EBPS (Exhaust Back pressure Sensor) is probably full of carbon. Some people clean the tube out using a piece of wire chucked up in a drill but the tube is so cheap that it is much easier to replace it. The sensor is located on the front of the engine near the high pressure oil reservoir. The tube runs from the sensor down to the right exhaust manifold. The tube is kinda hidden behind the a/c or alt bracket but once you look for it you will see it.
As long as it's stuck open I wouldn't get too worried about it. It's only purpose is to help warm up the cabin air quicker. It dosen't benefit the engine at all. Plus, like Crumm said, they can operate independantly of each other.
Normally (but not always) if the EBPS is plugged it will let you know by tripping the SES light when you've got her wound up.
Well, I'd like it to work, that thing takes forever to warm up without it, was 28 degrees this morning, My buddy's 01 has been closing the EBPV when he fires it up at work for a week now(take a look at my location, I'm 400 miles north of MN... It gets freaking cold up here)
It is not stuck, I can move it by hand. I guess I'll have to check and see if that tube is plugged.
If you take a test light and check for power at the plug you will find a weak pulsing signal blinking about three times per second. The test light will blink from one of the leads at all times whether the valve is to be opened or closed. The other lead is ground and will never blink. When the PCM commands the valve to close the blinking signal will continue to blink but just get brighter. So it will blink dimly when the PCM wants the valve open, and blink brightly when the PCM wants the valve to close during fast idle. If all that is proper then you can know that the problem is in the valve solinoid or something else.
If you have somebody turn the key on while you are watching the valve you will see it cycle if it is working. My understanding is that they cycle every time you turn on the key.
No they require oil pressure to work. Engine must be running for that.
I had the same problem and found that I had a code telling me the backflow pressure sensor was bad. I always read 40 psi even when the truck was off. If the PCM sees a fault with this sensor it disables the valve.
I have to disagree with you on this one. Since the valve puts backpressure on the engine, it helps to raise EGT. The primary purpose of the valve is to help warm up the engine, not the cabin air. Of course, when the engine warms up the cabin air also warms up.
Unless you live in an extremely cold climate I wouldn't worry about it. Although it is supposed to help the engine warm up quicker, most people don't notice much of a difference once it is disconnected. In extremely cold weather it does help warm up the engine.
At -50 the PSD engine will never warm up without the EBPV or by driving down the road with the front-end completely sealed up. The engine will also cool down if idled even for a short period of time. The EBPV puts a little load on the engine and keeps it nice and warm. When it is really cold out the valve will cycle going down the road for many miles. When you are accelerating it will open but if you are just cruising or decelerating it will close. Many people get the idea that the valve it not needed and either disconnect it or some even gut it to get better exhaust flow. I choose to keep both of mine working for our cold weather.
I've kept mine hooked up because in the next couple of years I'm going to be moving back to New England. I agree, it does help keep the temps up. Even when it's 0 degrees idling for a short period of time will cool off the engine.
