Sponsored by: Real Truck
Buying Wheels need help!
Old Oct 12, 2004 | 10:01 AM
kingz489's Avatar
kingz489
Unhappy Buying Wheels need help!
I am putting together my lift and wheel package. I dont have the money to buy everything at once so Im buying what I can get now. Im looking at getting 35 x 12.5 x 16 BFG AT and a 6inch edge lift. My problem is when I went to order the rims, I read somewhere that the F250 is Hub-centric. THe rims I wanted were American Eagle at about 150.00 each. The only rims I saw that were hub-centric where made by Weld and close to 300.00 each. Then I saw that the recommended back spacing for the lift is 5 inches. Weld only makes that back spacing in a 17 inch which adds more to my cost making me get 17inch tires! I dont want to spend that much and I know Ive seen 35 x 16 x 12.5 only some trucks out there with lifts. Anyone else go through this ? Thanks
Mike
Old Oct 12, 2004 | 12:09 PM
DCSpecial's Avatar
DCSpecial
Yep, AE Wheels are lug centric.
Weld and Alcoa are the only ones that I know of that make hub centric wheels.
I'd go with 4.5-4.625" Backspacing. If you are going with 16s be careful with Welds since many of the styles only come in 3.625" BS in the 16" size.
Hope this helps.
Old Oct 12, 2004 | 08:31 PM
kingz489's Avatar
kingz489
Thanks for the reply. I talked with someone at SDHQ and they said they have run lug centric with no issues. So Im swaying to Eagle 102 18x10 inchers.
Old Oct 12, 2004 | 09:54 PM
DCSpecial's Avatar
DCSpecial
Lots of people run lug centrics without any issues.....I have 27,000 miles running lug centric wheels so far.
Old Oct 12, 2004 | 10:06 PM
tomslusher's Avatar
tomslusher
Just this evening I installed American Eagle series 102 wheels, although they are only 16 X 8 so that I can put on Nitto 285/75R16 tires without the centers wearing out prematurely, like the last set of Nitto 305/70R16s did on stock wheels. Which center caps did you use for the front? The ones they sent look kind of stupid, too big?
Thanks,
tomslusher
Old Oct 12, 2004 | 10:48 PM
DCSpecial's Avatar
DCSpecial
I agree that the center caps for the front wheels look bad.........that's why I don't run them:
Old Oct 12, 2004 | 11:16 PM
kingz489's Avatar
kingz489
How do you like those PJs, I was looking at those and the Toyo, BFG all Terrains. Still undecided
Old Oct 12, 2004 | 11:35 PM
DCSpecial's Avatar
DCSpecial
I have a little over 1000 miles on them and so far I like them alot. They hum a little on the street but ride pretty smooth. I used to have 35" BFG ATs and what I always hated was the amount of gravel they picked up and threw at the truck. So far I haven't heard any getting thrown with the PJs and I've had it in the gravel a lot with them. Plus, the PJs sound a lot cooler when you spin them...a bit more of a howl to them
From what I hear, the new Toyo Open Country M/T tires are supposed to be the hot tire to get. Everyone I know with them loves them.
Psyclopse
Nov 7, 2014 10:35 AM
mizzitch
Jan 20, 2013 05:25 PM
ComputerCowboy
Jan 23, 2012 09:31 AM
snoVVman
Aug 2, 2004 11:22 AM
TrueBlueV10
Feb 20, 2003 06:13 PM
