front end grinding noise?
Old Nov 26, 2004 | 10:39 PM
KC Hotshot's Avatar
KC Hotshot
Sounds a little far fetched to me. I'd definately get more than one opinion. What gets me is that your problem goes away if you come to a complete stop. That's just strange. Can you switch to 4WD on the fly? If so, give it a try next time the noise/vibration starts and see what happens. If the noise goes away instantly, they're feeding you a line of bull. I lucked out, It seems all my troubles were caused by bad lockout hubs.
Old Nov 27, 2004 | 12:38 PM
96ford4x4turbodiesel's Avatar
Originally Posted by paramedic624
Hey everyone---In reference to the above thread......my F-350 is still making this loud vibration/grinding noise in the front end when I hit the slighest bump in the road it starts this vicious noise until I come to complete stop and start all over again. I had someone look at it and they said it was: Both tie-rods, ball joints and the trac bars----all causing this vibration........DOES THIS MAKE SENSE TO ANYONE!!!!?????
here is something to try grab your steering bars and see if they swing back and forth, or get someone to get in your truck and have them turn the steering wheel back and forth and if your steering bars (tie rod ends) move forward and backward then your tie rod ends are out if not then that aint your problem
elishaman
Apr 20, 2016 12:30 PM
Bigtruc
Mar 31, 2016 09:38 PM
jstorey2
Oct 8, 2011 07:36 PM
kilbrethj
Oct 1, 2008 09:06 PM
habby19
Dec 13, 2005 10:38 AM
