Noise in front end
Noise in front end
2013 f350 with 19k miles has noise in front end when going over bump in certain conditions such as when turning from a level road onto a downhill side road. Sounds like squeaking, grinding noise and I feel a sensation in brake pedal like the abs. No codes set. I can turn off traction control and it will not make noise. Dealer can not find any problem. Please help!!!!!!!!
My 11, 250, 6.2 does it too. Left turns from one level to another level like when turning left from an intersection with a curb side drain going across the road at 10-20 mph. Wonder if the ABS sensor is crudded up on that side making it less sensitive to the reluctor tone rings highs n lows?? Or the tone ring is crudded up?
lloydmiiller
08-27-2009 10:09 PM
