front end grinding noise?
Old Oct 10, 2004 | 07:19 PM
adamshee's Avatar
adamshee
every once in a while when im driving down the road and hit a bump, this really loud grinding noise starts, then as soon as I hit another bump it stops, it sounds pretty bad, I can hear it over the radio and i can feel it, feels like its comming from the front drivers side. Ive looked down there and I cant see anywhere that looks like its rubbing. My 4 wheel drive all still works, brakes, everything works. any ideas?
Old Oct 11, 2004 | 01:44 PM
mybigredford's Avatar
mybigredford
i sort have have that same problem, but not while driving down the road, i have to be just idleing and when going slow maybe 5-10 mph i hit some little bumps or if the front end compresses alittle mor than usual and it sounds like something is rubbing or ginding. it does it to when i go over speed bumps slow. everything looks fine under the vehicle too. i was thinking a ball joint but i think i would have felt something in the steering while driving. truck tracks fine and smooth. the sound appears to be coming from the drivers side front somewhere. could it be just leaf springs rubbing together??
Old Oct 11, 2004 | 02:00 PM
Kwikkordead's Avatar
Kwikkordead
Loose wheel bearings is what I think. Get the weight of the truck off of the wheels and push/pull in and out on the top and bottom of the wheel. There should be no in and out movement whatsoever. Only rotation of the tire.
Old Oct 11, 2004 | 11:47 PM
paramedic624's Avatar
paramedic624
there is definately a pattern here.....my 99 F350 4x4 PSD just started doing the exact same thing.....what the heck is that grinding/rubbing noise?????did u guys ever find anything wrong.....I dont wanna just start replacing or take it to the stealership........HELP fellas!!!!!! It comes and goes......exactly like u guys described....
vince
Old Oct 12, 2004 | 01:34 AM
rockyrider's Avatar
rockyrider
I'm there too, with my 97 F350 4x4 cc. Comes and goes, although more frequently now. Sometimes it right after I hit brakes, other times it happens when I let up on accelerator, or make a turn at slow speed. Could be at high speed also, but who could hear then. I hope someones got the answer to this, I don't want to be throwing money into a guessing game, but don't want to break down 500 miles from home. Boy wouldn't the stealership wolves love that.
Old Oct 12, 2004 | 02:33 AM
fedextech's Avatar
fedextech
try this test...manually lock in the front hubs ( it's not necessary to put it in four wheel drive) and drive over the road where it ussually makes the noise. is the noise still there? if not, your problem is probally the 20.00 roller bearing that is in the rear of the front wheel bearing hub assembly. the hub assembly is not serviceable BUT if you remove the hub from the spindle, you can then drive out the old roller bearing and drive in the new one ( ford item). this bearing supports the axle shaft and when in 2 wheel drive and the hubs are released,it spins around the stationary axle shaft. when the bearing starts to sieze up, it tries to turn the axle shaft...this causes the noise you are describing. the new front wheel bearing hub comes with the bearing, but it's not necessary to replace the hub assembly, around $100.00. i hope this helps you !
Old Oct 12, 2004 | 02:53 AM
fedextech's Avatar
fedextech
sorry for the typo... the price on the frt hub is 200.00 - 300.00, depending on your discount. if it's your lucky day, it'll be the roller bearing !!
Old Oct 12, 2004 | 06:12 AM
rockyrider's Avatar
rockyrider
I don't have manual locking hubs, so I assume they are always locked. My noise did start a day or two after engaging 4wd just for short period of time. I don't really use it this time of year so I will engage it once in awhile for maint thing.
Old Oct 12, 2004 | 06:24 AM
fedextech's Avatar
fedextech
on your front hubs, do you have anything ? or is it just a blank cover ? mine has esof and on the hubs, you can put it in "auto" or "manual". never the less, you can run the same test with it in 4wd, just be carefull on dry pavement.
Old Oct 12, 2004 | 10:12 AM
rosa70's Avatar
rosa70
I had the same problem. It turned out to be the caliper was not slidding properly on the disc brake caliper pin bolts which cause the caliper not to release properly. It would sound like it was grinding than go away. I rebuilt the calipers and flushed out my brake lines totally. I got a new caliper pins and greased them up real good. Totally stopped making the noise.
A few other things you want to check would be the thickness of the rotor. If its to thin this will cause the caliper piston to come out to far which causes it not to release properly. Next would be check any retaining nuts for the hubs or bearings and make sure there tightened to the proper specifications.
Old Oct 12, 2004 | 10:58 AM
mtgrzlyman's Avatar
mtgrzlyman
i had the same type of noise and it was the leaf springs rubbing. ford installed some plastic spacers
Old Oct 21, 2004 | 03:15 PM
KC Hotshot's Avatar
KC Hotshot
Here's my 2 cents worth...
Same intermittent problem on the front drivers side, only I describe the noise as an elephant with a head cold. There is drag and it's worse on the highway when speeds get up to 70 or 75. Sometimes lasting for just a second, other times for 30 seconds or so. Last time it happened for an extended period of time (I was going about 45) I kicked in 4X4 high and the noise instantly went away. I swapped the existing lockouts and that noise went away. However, now I hear a noise that sounds very similar to a warped rotor (a rubbing wump, wump, wump). Problem is I don't "feel" the noise when I brake and the braking doesn't silent the noise. I sounds as if it's now coming from the front passenger side. Since the original noise that was on the drivers side is gone and the new noise is on the passengers side, could a bad lockout be the cause of both problems?
Old Oct 22, 2004 | 01:46 AM
fedextech's Avatar
fedextech
Thumbs up
yes , it could be a lock out hub not releasing completely. have you tried switching (turning) it from manual to auto and back again, a few times ? you might have to disassemble it and check it aout if that does not work. have a ford day!
Old Nov 26, 2004 | 07:55 AM
paramedic624
Hey everyone---In reference to the above thread......my F-350 is still making this loud vibration/grinding noise in the front end when I hit the slighest bump in the road it starts this vicious noise until I come to complete stop and start all over again. I had someone look at it and they said it was: Both tie-rods, ball joints and the trac bars----all causing this vibration........DOES THIS MAKE SENSE TO ANYONE!!!!?????
Old Nov 26, 2004 | 12:36 PM
paramedic624
Unhappy
anyone? Im no mechanic, but this doesnt sound right.
