bed bolt help
Old Aug 11, 2008 | 07:24 PM
projectbad78's Avatar
projectbad78
bed bolt help
hey, im trying to take my bed off... i got about 3 bolts off, but the others are just turning, any tips to get these off...i dont have a torch...p.s. -i dont care about the bed
Old Aug 11, 2008 | 07:31 PM
1985 Ford F-150's Avatar
1985 Ford F-150
Cut the heads off with a grinder.
Old Aug 11, 2008 | 08:00 PM
projectbad78
i started to try that, but it would take forever
Old Aug 11, 2008 | 08:03 PM
Dr. Dirt's Avatar
Dr. Dirt
why don't you put a wrench on the bottom and put an air wrench on the top?
Old Aug 11, 2008 | 08:09 PM
tenforty_2's Avatar
tenforty_2
What a pain! I went through this last week! I took an air grinder with a cutting disc and cut a square in the top of the bolts. Then I took a BIG hammer and chisel and knocked the bolts down through the frame. Wasn't too bad once I got going.
Old Aug 11, 2008 | 08:37 PM
projectbad78
it is a round head on the top
Old Aug 11, 2008 | 09:40 PM
4x4 Bart's Avatar
4x4 Bart
4" grinder will cut the head off one in about 2min.
Old Aug 11, 2008 | 09:42 PM
4x4 Bart's Avatar
4x4 Bart
Start on one edge and get it red hot then it will slice it right off.
Old Aug 11, 2008 | 09:54 PM
fastfarmer's Avatar
fastfarmer
2nd that. My 4 1/2" DeWalt will grind the heads off those bolts in no time.
Old Aug 11, 2008 | 10:48 PM
daddy172005's Avatar
daddy172005
I had to grind the heads off mine too. Only way to do it that I know of.
Old Aug 11, 2008 | 11:16 PM
76CamperSpecial's Avatar
76CamperSpecial
Back when I was younger with limited tools, I needed the bolts off of the bed on an '85 Ranger. I took it up to a local shop and for $10 they went ahead and torched 'em off for me. Drove home with the bed bouncing a little loose, but it was just a few blocks over. Just a thought before you burn through a few grinding discs/waste a little time.
Old Aug 12, 2008 | 12:14 AM
ken selvy's Avatar
ken selvy
I used a steel blade sawzall once on the bed bolts .
Old Aug 12, 2008 | 04:15 PM
80F100man's Avatar
80F100man
Just chisel around the bolt heads till the bolt is loose, then pull the bed off, what's left of bolt will then be easy to vise grip center of bolt and take the nut off however you want to
Old Aug 12, 2008 | 08:34 PM
projectbad78
woo-hooo...... apparently all i needed were thinner cutoff blades for my grinder...that was so easy i dont even know why i crawled underneath there in the first place....thanks guys for all of your input
Old Aug 12, 2008 | 09:53 PM
RedUgly77's Avatar
RedUgly77
glad you got them off.. i had to grind mine off as well.
