Sponsored by: Real Truck
rear end gears
Old Dec 4, 2003 | 11:49 AM
78fordman's Avatar
78fordman
rear end gears
I have a 2000 F-250 diesel 4x4, and i need to know what gears i have in the rear differnetial. I have the tag off of the diff., and it says this:
S3 409 H
310 5 0F08
Does anyone know what gears i have?
Old Dec 4, 2003 | 11:54 AM
Brian Dearborn's Avatar
Brian Dearborn
Look at the sticker on your door jamb and go here
[https://www.ford-trucks.com/framered...erDutyFAQ.html
Then go to the rolling chassis link and click on the code sheet link in the third question.
I tried to link directly to it but it wouldnt work.
The tag you are looking at has other codes on it.
Old Dec 4, 2003 | 12:19 PM
78fordman's Avatar
78fordman
The axil code is missing on my tag
Old Dec 4, 2003 | 12:23 PM
n578md's Avatar
n578md
You are missing the first 2 or 3 characters on the second line but your tag says either :
S3 409 H
3.73 10 5 0F08 or
S3 409 H
3L73 10 5 0F08
The S3 is Sterling Plant
409H is the revision number
3.73 is the ratio
3L73 is 3.73 with limited slip
10 5 is 10.5" ring gear diameter
0F08 means this axle was made June 8th 2000.
Old Dec 4, 2003 | 06:56 PM
RRMike's Avatar
RRMike
All srw psd's have 3.73 gears.
mtdorf
Dec 15, 2012 08:09 PM
dirtracer2a
Dec 28, 2011 12:01 PM
jimi
Nov 19, 2008 02:17 AM
badfl97
1997 - 2003 F150
May 28, 2004 05:12 PM
xtrmbkr
Nov 18, 2001 08:37 PM
