Rear End Q's
Old Sep 22, 2010 | 03:25 PM
DieselSmoke67's Avatar
DieselSmoke67
Rear End Q's
I'm new to this forum, and to the ford scene. I have a real quick question? My brother has a mid 80's ford 1/2 ton stick truck and the rear end went out in it i got the tag numbers off it. I was wondering if anyone could tell me what type of rear end it is? 9" or whatever else ford makes.
S806A
08 88 6G22
those are the numbers i appreciate the help.
Thanks
Old Sep 22, 2010 | 03:51 PM
f100jim's Avatar
f100jim
You missed the first character in the 2nd line. There should be a number to the left of the 08.
Your second line is probably:
3 08 88 6G22
This is a 3.08:1 open carrier 8.8" rear.
If it is 3L08 88 6G22 it would indicated a 3.08:1 posi carrier 8.8" rear.
Old Sep 22, 2010 | 03:56 PM
DieselSmoke67
Thanks Man, yea thats all the numbers i could see on it.
Old Sep 22, 2010 | 04:39 PM
bashby's Avatar
bashby
The first # is usually hidden by the bolt that holds the tag on
Old Sep 22, 2010 | 04:40 PM
Franklin2's Avatar
Franklin2
They always poke the bolt hole through the first number.
Old Sep 22, 2010 | 05:16 PM
DieselSmoke67
Yea I pulled the cover off after ordering the parts, again thanks for the info guys, and yea u could barley make out the first number.
Old Sep 22, 2010 | 11:40 PM
Sport45's Avatar
Sport45
As has been said it's a 3.08 ratio 8.8" rear. The pinion bearing went out on our '83 F-100 a little while back. It now has a 8.8" out of a '91 F-150 under it. just took $200 at the wrecking yard and a few hours of sweat equity.
To keep the same axle and ratio just go to the salvage yard and find a F-100 or F-150 with an axle code of "18" or "H8" on the door jamb sticker. The H8 code is for the limited slip model.
fromm
Aug 8, 2011 11:42 PM
Ford400Man
May 9, 2008 05:09 PM
davidsca
Mar 11, 2006 08:10 PM
mikefox670
1997 - 2003 F150
Apr 16, 2005 10:27 AM
